Best brake upgrade possible???!!!
(In Topic #123603)
I was considering MK3 GTI callipers and necessary adaptors etc with braided hoses and some nice, fast road pads. As I don't think i'll ever bother with rear disc conversion I want the sharpest most effective set up on front.
Suggestion pleeeeease.
In Dorset, a "technical" usually involves bailer twine and a lump hammer…….
or leave them as standard and live life on the edge a little
Bearing that in mind you'll want 16v master cylinder and mk2 servo with braided hoses. bout as good as you'll get
1992 Clipper Cabby - Love VW!
yes you can. rally design do a 247mm set up, which will fit under 13" rimsg60bron said
Can't go any bigger than the std 239's if you want 13's
No idea how effective they are…I would have thought more people would do it was worth it. Bear in mind it would need a master cylinder direct off the pedal (ie proper pedal box). Plus it needs vac feed from intake still…
this thread is damn useful:
http://www.nsra.org.uk/forum/topic.asp?TOPIC_ID=13193
