Engine Detailing
Engine Detailing
very good keep us posted bro
Got some more plating done today.
This is what it is going to look like when put back together
Some painstaking effort going in there
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Water pump halves bolted back together with new gasket and freshly plated bolts.
Cleaned distributor with Ali-Clean then a light spray of Diamond Clear. Then put back together with the newly plated parts.
Looks brand new!
keep up the fantastic work mate
Matt
I wish I spent more time detailing when I done mine…I ended up rebuilding pistons and everything so bypassed the detailing mostly :roll: . This looks cracking!!! When I done mine I struggled to take the flywheel off as it kept turning… I done the same as you with the pressure plate though which made it easy….. how did you remove the flywheel, any tips?
Stripped sump down to bare metal then Degreasing, Metal Ready, Etch Primer and top coated in Under Hood Black spray
Sump bolts and a few other bits being Zinc Plated in tank
Bolts out of tank
Now this is the clever part, the freshly zinc plated bolts are immersed into a zinc blackener solution until uniformly black
The newly blackened parts are sealed with WD40 then refitted
More plated stuff!
Wiper mechanism components stripped. Frame and motor painted with Eastwood Clear Zinc spray and other parts yellow zinc plated ready to be rebuilt
Rebuilt
Bonnet lock stripped, cleaned and yellow zinc plated
Refitting
and in the middle of the same process
So far happy with the results of the yellow zinc, but with the black, i was told this was only OK for internal parts.
Is this why you are using WD40?
I started to go down the silver, or stainless, route for bolts, but would prefer to have a good solution for black.
Keep the updates coming 8)
Stripped alternator down and rebuilt with new bearings and regulator from JCR Supplies
Red primer from Halfords is used and top coated with Diamond Clear
Gear linkage parts cleaned up and zinc plated. New bush and ball kit from Crazy Quiffs
Oil cooler sprayed with Aluma Blast. Bracket and bolts cleaned up and zinc plated
Rebuilt
Head lights cleaned and back plates zinc plated
Rebuilt cylinder head cleaned with Ali-Clean and a wire brush then a light coat of Diamond Clear. Fitted to block and correctly torqued up with new bolts.
Cam cover and injection manifold fitted, all with new and original gaskets.
1992 Pearl Green Clipper Cab - 16v (9a block, KR head, GSXR600 Carbs)
I hope they look as good as your stuff.. Really look forward to seeing your finished Engine.
will be interesting to see it in the bay. might give yomps a run for best engine?
