Mk1 golf gti, 2L 16v, R1 Carbs. Nurburgring Nordschleife
Mk1 golf gti, 2L 16v, OZ turbo's. R1 Carbs
keep up the good work
Dubwanabe said
U dont waste much time do u looks great love this car
I have'nt got much time lol, its my daily so i having to get lifts with the missus when she goes to work. Good job i did my crimbo shopping before i took it off the road
92 caddy, Now stripped for full rebuild
83 golf gti R1 carbed 16v(soon to have 1.8T)
07 Leon FR TDI daily
Cambridgeshire regional host
Its running and i drove it home
Pic of the bay
Few things i not happy about
Position of throttle and clutch cables, going to re-route them so they look tidier.
The mk1 gti fuel lines was'nt long enough to tuck them away so they have to stay til i get some made or if i find the PL 16v lines.
I wired it up using the mk1 gti loom then added in the KR ECU loom which i shortened. The ecu is now neatly tucked in the rain tray and attached to the TCI unit, just how i did in my caddy.
Because i was'nt running the full KR loom, i could'nt use the ISV set up for controling the idling.
I used the AAV from the old gti engine which i chopped its mounting bracket off and filed down so it was just a neat cylinder.
After priming the pump so the fueling was under pressure, turned key fully and she started first time, Result.
Would'nt idle at all though then i realised i forgotten to connect the vacuum pipe to ecu :roll: , Yes i was in a rush to get her done.
Once sorted, she idled brill with just a little adjustment with the Idle screw on the TB.
Set my gear linkage up which work perfect first time then went for a spin(literally).
Its twice the car it was before. Goes, stops and sounds great.
16v Conversion, Brake upgrade and stainless system done in 3 days. Get in there :punk:
I wish I could get my conversion done that fast
nice photos.
and those wheels…..sick.
tell jan my maw is asking for him.
peac.e
'83 Black GTI Cab on BBS RAs - DreamBoat 3000'
Resto = http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=67552
Now sits in front of the rad
It can work either by pushing or pulling air, just depends which wire you use for the positive.
Much tidier than the original unit
mk1 golf - resto
mk3 polo breadie - daily banger
boyle_sbd said
cars lookin real good man, where an how much did u get that fan, bn lookin around for one like that that can run both ways. how did u mount it?
Cheers mate
Just tap '12 slimline fan' in on ebay mate. Theres also a fitting kit. Total cost was just under £30 delivered
mk1 golf - resto
RoadBoss said
The GTI should be a blast to drive now!
It is mate :twisted:
Love it to bits 8)
OZ turbo's, 15x7j and ET33's.
Had the wrong size tyres on so i removed them straight away at a garage i've been helping out at. Tinklers in Ramsey
No centre caps so plan is to have some made
Now searching for wider lips and some stainless RS bolts
The 4th wheel is at a machine shop as i'am having some flush centres made
I'am now looking for a pair of 1in and 1.5in lips, maybe 2in so the fronts will be 7.5's and the rears 8's or 8.5's
I've got a load of RS bolts, 1 set is chrome, the other is a darker shade which could be stainless but its hard to tell.
Also ordered 185/45/15 tyres
Oh, this is the look i going for other than shiney bolts to break them up abit
its gonna be perfect,
keep going… :wink:
As you can see, the 8.5in rears are a tad big so i've had to raise it
The 7.5 fronts sit lovely though
I've also checked the emissions, it was running very lean so i've now adjusted it so hopefully i'll notice better mpg and power 8)
They give the same look of stretch front to back mate.
I'll be fitting 185/45's all round on the 7.5 and 8in wide oz turbo's
