MK1 Golf GTI 2.0 TFSI Edition 30 p12 (was 2008cc R1 bike carbs)
(In Topic #149291)
1983 Lhasa Green MK1 Golf GTI
This is my 1983 Lhasa Green MK1 Golf GTI TFSI. I am the 3rd owner from new and have now owned this car for over 25 years!
Starting out at 100% original, it has been slowly improved (abeit 'modified'!) slowly over majority of these years, when the original parts needed replacing or a bit of TLC.
Current spec is Golf GTI 2008 Edition 30 BYD TFSI 2.0 16v Turbo.
Six Speed Manual gearbox with Quaife LSD and custom 02j/02s 20vt/TDI ratios.
Stripped out interior, Custom Cages Club Sport six point weld-in roll cage.
Bucket seats, four point harnesses.
Light weight polycarbonate windows.
Full MK5 Golf GTI wiring with coming home comfort/remote lights on module retained and retro fitted to MK1 lights.
Wilwood 4 piston and 280mm G60 front brakes.
Polo GTI 6N2 rear disk conversion with 16v Scirocco handbrake cables.
Canbus Rev Counter with needle sweep on startup.
Canchecked MFD28 digital display
MK2 Golf GTI 16v 8000rpm 160mph clock conversion with digital VSS output.
MK2 Golf GTI stalk conversion.
Hydraulic clutch conversion.
Custom wiring loom.
Custom Coded Modules/ECU.
Custom Engine mounts.
Custom OEM+ TFSI fuel tank.
Custom intercooler pipework.
Custom radiator pipework.
Custom radiator mounting points.
Custom bracket to mount drive by wire accelerator pedal.
Custom 3" decat exhaust with 3" centre silencer connected to Supersprint Group A rear silencer.
Carbon fibre bonnet.
Previous engine spec was a
2008cc 8v engine block (2 litre crank, 83mm pistons)
Grant Motorsport split timing fast road cam
Grant MotorSport 41mm inlet/36mm exhaust big valve head
Custom ported inlet manifold to connect to R1 Bike Carbs
Yamaha R1 bike carbs with 190 main jets
Supersprint Group A exhaust
Supersprint four branch manifold
13 row Mocal oil cooler
UPDATE! Custom Cage ClubSport weld in rollcage now installed and K04 TFSI Golf GTI Edition 30 engine conversation now under way, see pages 12 onwards!
Last edit: by Lhasa2008
smudger1980 said
Looking good mate. Don't worry mate about the rust pics I'm sure yours won't be anywhere near as bad as some of them on here![]()
Ha! I'm up for a challenge!
When during the MOT, the garage was able to put a screwdriver right through the out sill to the inner sill, I knew it was time for some bodywork to be done! This was circa 2001.
Firstly, I then had to learn to weld and not just to blow holes in everything. :wink:
And secondly, I needed to get a shopping list together for needed replacement panels, which at the time was more difficult than I realised. Many panels were already obsolete, even back in 2001!
This is what I managed to find
Both sills, the first set got returned as they didn't have the swage line in them.
rear inner sills (genuine), rear outer arch repair panels, rear lower valance, and front wings (genuine).
I also managed to source a genuine vw side member part number 171801391. I believe this was one of the very last available at the time.
Side member 171801391 £18.90+VAT
Housing 155803436E £72.00+VAT
Housing 155803435A £53.95+VAT
Sills (each) £22.00+VAT
Filler neck repair panel £13.50+VAT
Front wings £80.00 + VAT
How does that compare to current pricing?
Rear inner arch being cut away.
It's not until you do this sort of thing, that you realise how little metal (protection) there is between you and the car if you were ever unfortunate to have an side impact..
Fuel filler neck cut away and outer arch cut away. Note the nibbler in the background from Frost. Brilliant gadget, brilliant shop!
Genuine VW repair panel being cut to size.
Time to cut away the sills, carefully removing all the spot weld as we go.
New sills now tacked into place
Eventually got back to solid metal for rear axle and new panel tacked into place.
sills sprayed in primer. Not a bad fit, and not bad for first attempt!
There was only a little surface rust, so this was sanded back and protected with a zinc based primer, while the rest of the car was being put back together.
So while the rear axle was off the car, I took the opportunity of upgrading the anti-roll bar to a 28mm Neuspeed one, and repainting the rear axle with Chassis Black (from Frost's)
Fortunate, to be able to source some new axle bushes and mounts, as the old ones were beyond repair.
Inner arch now reprotected and a quick coated of paint applied.
zinc primer and chassis black applied to floor pan and underneath boot floor.
Spot the difference competition:
1983 VW Golf GTi Black (Resto)
2009 AUDI Q5 3.0 TDi (Daily)
2007 AUDI A4 Avant TDi S-Line SE (Daily)
The main problem was how extensive the rust was once you start cutting and grinding it away.Crease said
looking good! seems pretty involving job!
What looked like surface rust, wasn't just surface rust.. 8O
MalC said
Very nice mate lots of good work gone into save this
