Limited grip, slippy front end, yet, camber, castor and tracking is perfect....
(In Topic #191865)
Could it be the power steering?
I had my car full four wheel alignment checked today and was advised that everything was perfect, but what the chap couldn't tell me was that could there be an issue with the rack being of Toyota Starlet supply. I am considering if the two front wheels could somehow be turning at a different rate to each other, thus the only time I do get grip is on a dead straight road. (dry)
- Rack is about 20k miles old, toyota starlet
- tyre wear doesnt overly show excessive outer or inner wear, just tread pattern is uneven
- there is no play on the lower front end or suspension at all
- Car is lowered, Eibach and inserts in standard struts
- There is no obvious movement, anywhere. Until it rains and there's a Mk1 Golf sliding all over the place
Anyone experienced this, or can advise how to or who can rectify? thanks
Google TOOT; Toe Out On Turns. If you have kept the original hubs and therefore steering arms then the TOOT could be changed by having track rods and steering rack that are a different length compared to original. The overall length may be the same but the angle that the track rod and steering arm create whilst steering will be different.
Hope that makes sense.
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
Increased tyre wear
Vehicle breaks away when negotiating bends
Poor steering return in case of large steering angle.
pretty much what you have?
My VAG family:
My VAG family:
i had some Debica Passio tyres (C rating in the wet) on some wheels which I bought which had plenty of tread left on them, in the wet they was terrible I could spin the wheels in 3rd and after nearly driving in to a hedge on a bend in the wet I changed them for some better tyres (Hancook at the moment) and I don't have any problems taking the same bend at the same speed in the wet now.
Terrible tyre link….
http://www.mytyres.co.uk/cgi-bin/rshop.pl?dsco=110&cart_id=10386673.110.3793&sowigan=So&Breite=185&Quer=60&Felge=14&Speed=&kategorie=6&Marke=&ranzahl=4&tyre_for=&x_tyre_for=&weiter=22&rsmFahrzeugart=ALL&search_tool=standard&Label=F-C-70-2&details=Ordern&typ=R-157994#
What's the cure? Some really complicated geometry alterations… or reluctantly replace with standard rack?
Tyres?, Toyo Proxis. I used to have these on my tin top, and can't remember any issues wet or dry. I was thinking of changing over to the ultra reliable P6000.
This is definitely progress!!! thanks
I'll take my tooting tale back to Mr steering fixer-upper tomorrow.
Jack
Is your steering rack linked up to some sort of speed sensor so it's lighter at low speeds and heavyer at speed?
CF1
http://www.mytyres.co.uk/cgi-bin/rshop.pl?dsco=110&cart_id=6545823.110.9976&sowigan=So&Breite=185&Quer=60&Felge=14&Speed=&kategorie=6&Marke=Toyo&ranzahl=4&tyre_for=&x_tyre_for=&Herst=Toyo&rsmFahrzeugart=ALL&search_tool=standard&Label=F-E-70-2&details=Ordern&typ=R-118998
NE does better at a C grade
http://www.mytyres.co.uk/cgi-bin/rshop.pl?dsco=110&cart_id=6545823.110.9976&sowigan=So&Breite=185&Quer=60&Felge=14&Speed=&kategorie=6&Marke=Toyo&ranzahl=4&tyre_for=&x_tyre_for=&Herst=Toyo&rsmFahrzeugart=ALL&search_tool=standard&Label=E-C-69-2&details=Ordern&typ=D-113407
I value the drive more than I do the ease of slow speed parking manoeuvres, and there's an obvious danger element to this also. There's something to be said for all that research that VW or any OEM does before putting into production and who are we to suggest that our 'personalisations' and modifications actually improve the car. In many cases they do (personal taste aside), but when it comes to things like fitting power steering from a toyota, just because the column UJ and track rod ends almost match the Mk1 golf layout has clearly been driven by ignorance.
So, unless anyone knows of an alternative, it's back to the standard non powered steering version, and I'm looking forward to actually get some power onto the tarmac. The thread has also altered my tyre choice. I'll review this when replacement is due on the assumption that the new rack will resolve the issue with grip. I'll add an upper strut brace too, if I can get one to fit when I've got the ABF lurking under there.
For what it's worth, I've covered nearly 30k miles with the power rack on, mostly good, but the lack of grip after the ABF unit went in was just too much.
Thanks for the input guys, I'm kicking myself at the cost of the power rack installation, but having decent grip will make it much better in any case.
If anyone wants the power steering set up, let me know…If you're a dry road user only, it's fine, but up here in jockland, that choice isn't a choice! :-)
My VAG family:
My VAG family:
I've also heard that the some of the later south African citi golf had power steering. This would be good if I could confirm this too. I'd like to retain the power steering, but no longer at the cost of grip. I'll sift through the web and see if the citi golf's did indeed have power steering. Thanks again.
For power steering I've never seen the use of it unless you live in a city and do alot of parking in small spaces, as long as you don't try to turn the steering wheel when stopped as that is hard work, even if you move at a slow speed you can turn the wheel with a bit of pulling and once out on the open road any speed above 25 mph and I can turn my steering wheel gripping it with 1 finger and a thumb. I use my car daily so I may of just got used to it…
