1.8 GTI Injector Seats
(In Topic #203436)
However couldn't find an exact answer.
I've a later engine, going into an earlier car. Engine's having a full overhaul.
So why it's still in the shop I'm thinking of refreshing the injectors/ seats etc.
Now, it's the newer type with airshroud injectors + seats - little tube out the back and impressive looking brass inserts poking out the head.
I can't however find anywhere that stocks new airshroud injectors, or Infact can I find how the aux air bit works… Not sure whether it's worth the effort to reimplement ? Was blocked off when I got the engine.
So, first question - does anyone know where air shroud injectors are available?
Second; I assume the earlier type injectors can be put in with the older seats? Looking to this as can see the injectors for circa 27.50 each.
Can't find the correct seats though?!
Any help is appreciated.
Cheers,
Adam
'83 MK1 Golf GTI
'08 Audi S3 2.0 16v TFSI
You need to remove the seats while the head is off as they will break into little bits when you try to remove them as they are plastic and little bits will fall into your engine.
I know rubjonny has said there is not real differance with the air shroud system as he as tried with and without it running. I think the idea is to add an extra little bit air to the fuel while it's being injected into the engine to make a sort of mist?
You can still run the air shroud injectors with out the air running, just blank the holes off, there may be a hole in the rubber boot just before the throttle body if you have the later boot to match the air shroud injectors.
I'll find some pictures and info.
New ones.
Last edit: by mark1gls
http://www.ebay.co.uk/itm/VW-Golf-GTI-MK1-MK2-1-8-16V-Corrado-Lower-Fuel-Injector-Insert-035133554-/151567468047?hash=item234a20060f:g:UG4AAOSw-W5UxoFz
Or here.
https://www.vwheritage.com/shop/golf-cabriolet/035133554/insert-lower-fuel-injector-mk2-golf-corrado-16v-k-jet/?crumbStartPage=1&crumbStartRow=1
Some info here on what injectors and seats
http://volkswagenownersclub.com/vw/showthread.php/31001-fuel-injector-seal-leaks
I did get my injectors a while back and I can't seem to find any at the moment expect for vw heritage but I think they are £62.95 for one, I think I paid £25 ish each….
https://www.vwheritage.com/shop/golf-cabriolet/026133551/fuel-injector-mk2-golf-jetta-corrado-1800-16v/?crumbStartPage=1&crumbStartRow=1
I think purely on the price of the injectors it's looking more worthwhile to go with the older style.
Although I have a old turbo kit to stick on at somepoint … Not sure if the extra air might have a bigger benefit in that case.
Argh! Looks like this weekends reading… Kjet airshroud ha.
Thanks for the reply, much appreciated.
Cheers,
Adam
'83 MK1 Golf GTI
Chairman
I got mine from VW Heritage at the time.
