Rev Limiter Relay No. 62 VW Part Number?
(In Topic #194440)
I am getting different Part Nos for the Relay No. 62. Some say VW P/N 443 907 385B, others say 321 906 059G or 321 906 056G. Which is the correct one please?
I am also interested to know the VW Part No. for the correct Rev Limiter Rotor.
Last edit: by NoNameYet
321 906 056G is the part number on mine
http://www.ebay.co.uk/itm/VW-Audi-Seat-Skoda-relay-No-62-/281571941196?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item418efedb4c
If the relay you have works why worry about changing it? There is no benefit going to the red line as the power starts to drop off 5500 rpm and you have a rev counter fitted to the car.
There should be no mod to fit the relay just pull the old out and push the new relay in.
Mark, I know that the relay on mine is dated 07/95 so that must surely have been replaced at some point on a '91 car. Apart from that I have found info saying that originally it should have the rev limiter relay, so I want to change it for correctness and also for safety reasons in case something goes wrong with a stuck throttle cable as an example. I saw a BMW engine blow itself to self destruction a few days ago in such a case. I don't want to risk anything similar on mine.
May I ask at what rev limit does yours cut off please?
I've also got a Mk1 scirocco which has no rev limiter and that has gone above 7000 rpm then into the petrol guage (in my younger years of driving like an idiot!) but the power from the engine starts to fall away at 6000 rpm so no point going to the red line.
You can also get rotor arms which have a limiter built in.
http://www.ebay.co.uk/itm/MK1-GOLF-Rotor-arm-GTI-83-6900rpm-limit-will-also-fit-aircooled-/391034839634?pt=LH_DefaultDomain_3&hash=item5b0b7e2252
321 906 059G is the current VW part number for the 62 relay anyway
62 = 443907385b/321906059G / 3.300.220 / ? = 6.5k limiter?
63 = 321906059D-E-F / 3.300.210 / 935VG0090 = no limiter
65 = 321906059H / 3.300.230 / 935VG0080? = 6.5k limiter
