How to fix accelerator cable at pedal (once and for all)
(In Topic #143812)
You will need :
a Pair of pliers (maybe)
small e-circlip (ebay)
about 20 minutes of spare time.
My accelerator cable kept falling out. I'd be driving along when the pedal would fall to the floor and I'd be unable to accelerate. I'd have to put on my hazards, jump over to the passenger side, lean under the driver footwell and push the hook of the acc. cable back into the grommet.
Today I inspected and discovered:
my hook is bent…
my grommet ripped! You can get a replacement from VW part # 431721559 or from crazy quiff if you're a millionaire
So first things first, I have a look at a new accelerator cable (I'm a hoarder) to see how the hook should look
I take my pliers and replicate this shape on the bent original:
Then I use duct tape to further secure the now weakened grommet.
And finally, I use a wee circlip I had in my big drawer o' spares to secure the hook a bit better than VW intended
So now I piece this all together, with the ripped grommet end turned round…and this is feeling pretty secure
I push this back into it's housing in the acc. cable and we've finished stage 1.
For stage 2, we want to make sure that when the accelerator cable is at full stretch, i.e. the pedal is to the metal, that the throttle is fully open…
In other words, if you are using only 3/4 of the pedal travel to reach full throttle, the final 1/4 of travel, will only serve to stretch the cable, and result in pulling that bloody hook out!!
So first off, we disconnect the clip around the other end of the cable, and the clip at the rocker cover freeing up everything.
At this point, I call upon my trusty assistant and mother.
She has one clear instruction:
Push right down on the accelerator.
With the accelerator right down, I push the throttle to it's fullest position (the car is off at this point, just incase you have neighbours or like your engine) and reconnect the cable…
I then replace the clip at the rocker cover so that it's nice and tight with the cable at full stretch.
I then instruct mama to do a bit of down and up on the old throttle and make sure it's not being stretched at full throttle…everything seems in order here.
So I have one last check in the footwell to make sure the cable is only travelling straight and not an angle.
Satisfied, I take the dreamboat a wee spin and call it a job well done.
Peace.
'83 Black GTI Cab on BBS RAs - DreamBoat 3000'
Resto = http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=67552
Re: How to fix accelerator cable at pedal (once and for all)
It was the nearest thing to hand when I stuck my head under but worked a treat and the carpet clips diameter is larger than the grommet hole in the pedal.
I've now got a new grommet and still have a carpet clip on there to prevent a repeat of that brown trouser moment (accelerating from a junction onto a busy roundabout when the pedal hit the floor)!
I have used mine as a bump start pilot, my brother has used her to bleed brakes.
I am trying to convince her that she really wants to re upholster my interior for me.
mAtt-
there are several problems that can make the cable pop out!
1. cable too tight, adjust as above
2. cable end bent, adjust back to shape as above
3. accelerator pedal bent, bend and tweak till cable is pulled straight thru the hole in the bulkhead, not at an angle
4. cable old and frayed, replace
problems 2 and 3 are caused by problem 1! also there should be next to no resistance on the accelerator pedal, put a new cable on and its like a modern car! give the new cable a spray of silicone based spray lube too as new pattern ones can be a bit dry
Old thread i know, but any tips on where you can buy the grommet at the pedal end & the circlip at the rocker cover end for the accelerator cable for my gti
thanks
baz
COTM Team
http://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-SCIROCCO-GTI-CADDY-PICKUP-ACCELERATOR-PEDAL-GROMMET-C643A-/190837384403?pt=LH_DefaultDomain_3&hash=item2c6ecb64d3
aircooled1968 said
those rubber grommets are £4 form the baybazmk1
Nice one
baz
COTM Team
you dont need the clip, mine held in without one, its a push to get the cable in though, think this may be it
http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-CLUTCH-CABLE-GROMMET-C644-/200662085870?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eb86470ee
ive changed both grommets on my cabbies recently..i never checked before but one was just held in on the ring from the pedal..and the one on the GTI leech was bent back on itself creating a loop.. temporary fix that had ruined the cable, for the price of a £4 parts ends up £20 to replace the full set.
On the drive
Myvalver 89 GTi Grey mk2 16v
Just the clip now, i am did fussy when it comes to the crunch & really want to fit the correct part to my wee gti, mine is broke but still does the job but when i fit the new cable soon I really want to fit a new vw clip or a vgc second hand clip
http://www.ebay.com/itm/Vw-MK1-Golf-Caddy-Accelerator-Cable-Adjustment-Clip-NEW-/220555467108
OUT OF STOCK & across the sea
OUT OF STOCK & across the sea![]()
wow $9.99 postage.. must be made of gold.
On the drive
thanks
-z
i pressed the little red button
Clips like this and once pushed on they lock.
http://pages.ebay.com/link/?nav=item.view&alt=web&id=251853121659
I bought one from VW a few years back for a few £s it's a soft foam which has slowly disappeared over the last 4 years so now I've got 2 from gsf for less money than 1 from VW.
http://www.gsfcarparts.com/732vg0010
Do NOT buy MK1 golf bushes, they're rubbish, expensive and fail. buy MK2 golf ones, they're the same shape, made of hard rubber, and outlast the car. its one of the only things thats original on my 205k MK2 Golf
Have the mk1 bush on its way, but i will take your word for it & have just bought the mk2 bush as well of GSF
many thanks
baz
Any one got a VW throtle cable adjuster circlip above the rocker cover going spare? (see the photos above for reference if you like)
thanks
baz
