.Retro Blaupunkt Radio Ipod Lead ***HOW TO GUIDE***
(In Topic #145135)
so as i had mine in bits thought i would provide a bit of a how to
3.5mm Line Socket
6 pin DIN plug
Tools needed:
- Wire cutters
- Stanley
- Soldering iron[/list:u]
So here is what you do
cut one end off your Male to Male jack lead
then get you DIN plug and wire it up like this
put the DIN plug back together and job done!!! or so you think
When you have the DIN lead plugged in without anything attached, the radio is very quiet!!! like mouse!!!!!
so now you need to get the line socket and wire it up like this:
now this links the cable and makes the radio run at normal volume, when ever you haven't got you ipod attached this plug needs to be on so you can hear the radionow this is it!!! but your can run it a different way
i have a 3.5mm chassis socket mounted in the glove box. this replaced your 3.5mm male end
but this means you will need another 3.5mm stereo Male to Male Jack Lead this just make everything nice and tidy
total cost less £10 for ipod tunes on your retro radioif anyone wants one making if you haven't got the equipment to do so, i can do so send me a PM
enjoy!
