Rigid fuel line brass end fittings
(In Topic #141764)
Thanks for any help
http://www.scparts.co.uk/
M14x1.5 union to fit 5/16 pipe. I'll give it a try when i get it through the post and let you know how it goes.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
CabbyBrad said
Gsf sell em?
honest ? do you have a part number or anything ?
i've been going doo-lally trying to peice together a fuel line for the missus car, i've put a KR engine in place of her 8v carb engine in her clipper, i have bought an accumulator and a bracket for it, i know i need an external pump but before i get to the rear of the car to do this i want to finish the engine bay, i need to mate the fuel lines that are there to the K-jet and need the fittings !
DSC00706 by bonus!, on Flickr
As for the fuel line itself, its def 5/16 copper pipe. Wether this refers to the id or od i dunno, but quote that size to the factors or ebay or whatever and order 8m if youre doing front to back x 2. I used 7m, but its good to have a bit over. I cut mine too short, and had to join using male/female/male unions. This pic is in my flaring kit, leave about 5mm poking out, and make sure the former is dead square to the pipe, and the press correctly aligned.
DSC00703 by bonus!, on Flickr
For the metering head end i'm not sure exactly what fittings i need yet. Seems a banjo fitting is needed.
http://www.earls.co.uk…dapters/fueladapters.html
they were very helpful, it can help if you draw a simple diagram of the system front to back then you can list all the connectors male and female etc to make ordering much easier.
M12 x 1.5
http://shop.bgcmotorsport.co.uk/12mm-banjo-for-8mm-hose-m12x15-bolt-fuel-oil-71-p.asp
I have run my copper fuel lines into the bay to the drivers side mount. I will connect them here to the rubber lines using jubilee clips, run the last foot or so, then use the slide on banjo above.
That gonna stand the pressure??
