Vacuum hose layout
Later 1.8DX engine from a sportline
Im puting a 1.8DX engine into my caddy. It has the hydraulic head with the vacuum hose outlet at the rear. Does anyone have pics or can they help me out with where all the vacuum hoses connect please.
The engine that I am using came from a later cabby sportline.
Amazingly I might possibly have some if you only asked  :P
Cheers Chris.
Im struggling to see where the hose from the back of the cylinder head goes.
The pipe from the back of the head between cyinders 3 and 4 (Air supply for the air shroud injectors) goes to the rubber boot attached to the throttle body.
If you don't have the connector in the rubber boot you can just cap the end of the pipe coming out of the head as I know rubjonny says it does not make much differance so not really needed.
Last edit: by mark1gls
Thanks Mark that answers my question.
