timing marks
(In Topic #92201)
timing marks
All this week i have been trying each evening to get it going. talked to several people who have golfs and Im sure i have the engine at TDC. One very weird thing though - When I have cylinder 1 at TDC (looking in through spark plug hole and checking on the flywheel) my cam sprocket mark is pointing directly north!? i understand the mark should be aligned with the top of rocker cover? If I do put the cam to this point I can clearly see the piston is much further down on its stroke and I cannot see either the flywheel mark or the bottom pulley mark to bottom case arrow. The cam mark is also on the outside of the sprocket!? Something seems very odd. maybe the cam was changed and the sprocket put on 90 degrees out? Is that possible? Anyway i have tried to get it going with all marks at TDC but sprocket mark pointing north and I have also tried rotating 180 degrees and lining everything up but with cam sprocket pointing south - still nothing. I have check for spark at king lead and ht lead and there is definitely a good spark there. I have also had injector one out to check i have fuel coming through if i push the airflow plunger up which i do.
I read somewhere that the bottom crank turns 4 times to one turn of the cam? IF this was the was I should be able to get my cam mark to sit aligned with the rocker cover as Im currently 90 degrees off but I can only get it 180 so the crank must turn twice to one cam turn? That make any sense?
really lost now. this is the first every car I have carried diy maintenance on and everything has been pretty easy up to now. I consider myself pretty able where things like this are concerned but this has just baffled me. Any help would be GREATLY appreciated.
Sorry for the extended version of the story but wanted to make sure i missed nothing out!
Thought i would add some pics:
These pics were taken last night when I double checked everything was lining up. They were taken straight after each other without the car being touched.
Flywheel timing mark:
Dizzy lined up:
Bottom pulley lined up to arrow on lower cam casing:
Now look at the cam mark crazyness!
put something down hole 1 and get the piston to the top, TDC
check the fly wheel/crank pully mark is pointing upward.
line the cam up - locate the mark on the inside of the cam wheel and make sure that it lines up with the front face of the head. the outside mark will do all sorts of things so dont worry about it.
turn the dizzy to position 1/tdc mark belt it up, re check all stays in time after turning it by hand a few times.
start it up.
Basically i would think that the cam would not be able to have the sprocket installed wrong as it is keyed to stop it rotating etc.
im sure there will be a mark, its a line infact.
I can look at an 8v for you tonight and get a rough placement of the outside mark but its not the one to use really.
Failing that you could whip the cam cover off and look for the position with the valves open on 1 for tdc (i think)
sciroccotune said
try harder![]()
That would be a brilliant help if you wouldn't mind doing that for me. Knowing where your outside mark sits in relation to the inside mark correctly will tell me where my inside mark SHOULD be and I will be able to determine for sure that my cam wheel has an inside mark or not.
When you say a line do you mean similar in appearance to the line found on the dizzy body? looks like a scored lined made by a knife? I was looking for a small center punched hole. Will have another look tonight with more WD40 and some light wire wool. Thanks for your help.
but are you sure that you have the dizzy in teh right way anyway>?
It shoudl strike plug one first on a clock wise rotation.
Ill try and get some pics for you later anyway.
Thanks for all your help.
also for your viewing pleasure…..
8)
ps thanks for all the help sciroccotune
