Oil deflector - Should I have one?
(In Topic #72131)
My '83 GTI doesn't have a plastic oil deflector under the cam cover but my '88 Cabrio does. Should the '83 have one too?
Thanks,
Ross
Life Member
Can't remember if mine has one or not. I have a feeling they didn't on the early Golfs.
Anyone else?
Cheers,
Drew.
Once a Mk1 fan, always a Mk1 Fan...
I think I'll be fitting one next time the cam cover is off. It wouldnt do any harm and should only improve things if anything.
Ross
Life Member
Cheers,
Drew.
drew said
Ooooo… controversial…. is that a mod then?:wink:
Cheers,Drew.
This might help - MK2 GTI's running hydraulic heads had the additional Splash Gaurd fitted as standard. This was due to the Hydrualic lifters/ tappets used instead of the MK1 mechanical system.
Fitting the splash gaurd to the MK1 was an old mod that people did when they had the small gauze filter removed form inside the head as wihtout the splash gaurd and the gauze removed, oil woudl go down to the air box.
All the MK1's I've ever owned, I've always bought the gaurd and fitted it as it does help keep the air filter cleaner.
Hope htis helps Guys…
My 82' Gti (1.6, EG) didnt have an oil deflector fitted - part number 026-103-547 - and I wasnt aware the part existed, until browsing VW Heritage which lists it as a Mk1 part (1975-1983, 1.6 to 1.8 engines excl 16V).
Given that its a cheap part I've ordered one and will see how it fits - would be interested in any updates if anyone has good/bad/indifferent feedback.
