Coolant lines??
(In Topic #148773)
Coolant lines??
I'm having trouble getting my head around my plumbing system… It's an AEB conversion..
The AEB pipes wouldn't suit transversly mounted so i bought AGU pipes which didn't suit the AEB engine.. apart from the engine end flange…
So as complicated as all that sounds.. My simple question is does this drawing look ok for the layout of the cooling system??
Couple pf points i've noticed..
1/ Expansion off the rad
2/ Expansion wil fill back to a Y on the bottom rad hose?? Is there a better place? its gona be abit tight down there anyway..
3/ Oil cooler returns back to bottom of engine junction/fitting
4/ The matrix, is it ok to take that side exit from the water pump through the matrix back to block or should it return straight to block and T off for matrix?? Where would the T's come from?
5/ The throttle body warm up just get blanked off?
6/ Is there anything i've missed or doesn't look right??
I think i've got abit of a visual in my head where to route it all but the side exit coming past the oil cooler might be a bit tight? Any pics or info would be much apreciated
Thanx Shaun
\/\/ The beast to be…!!!
(loads of pics) \/\/
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=95838&highlight=
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
Any ideas on this buddy?
Thats a breather if thats what your on about?? For all the VAC pipes or to a catch tank
HTH
SSC ELECTRICAL
SSC ELECTRICAL
Cheers buddy!
The cam cover on the AEB dosent have outlet though so straight to catch tank.. but not sure weather to drill for one?? Not sure if the AGU cam cover will go on??
I suppose you could just stick a filter on the end of it.. but guess oil and sludge would to soon clog it and start to drip?
SSC ELECTRICAL
SSC ELECTRICAL
