1983 Standard GTI Concours 42000miles
Yomp said
Look what I found under 25 years of crud!
Before…….
After…….
Took a few hours and it certainly wouldn't win any prizes but its more inkeeping with its mileage now.
how did you clean that? the difference is brilliant
If you can read this, thank a teacher,
If its in English, thank a soldier.
A soldier fights not because he hates whats in front of him, but because he loves whats behind him.
ivortheengine said
i notice a little clip bolted on to the front of your rocker cover to hold the cabling in place what type is it, keeps things neat,
Don't know the part number but it is an original clip in steel.
This was the 1st Golf of 8 I've ever owned to still have it in place! I run the clutch cable through it but I have seen folk run the speedo cable through it.
I have a mate pricing them up for me but if there off the shelf it might be cheaper
funk-star said
Where did you get you fuel hoses from?
I bought them off Crazyquiff at a show in 2008 as a panic buy as I was worried about mine but then couldn't be done with the hassle of fitting them!
The german trip is the reason I needed to change them and look what it turned into……. a full on resto! :roll: which is also why I had put it off for so long!
It was a struggle to split the original lines without damaging or shearing the solid fuel line to the engine. I ended up removing the fuel tank, blowing out the lines to remove any fuel and anything else that could ignite in the vicinity and heating the pipe fittings so they glowed cherry red to get the threads to move.
I've since found a hydraulic shop who can do them as well who have made a load of fuel pipes for me for my land rover megasquirt project.
Not bad but it made the keys on the key ring hum in the ignition barrel but I'm terrible when it comes to unwanted rattles in cars and it don't half wind me up.
I've been uming and arring about getting the engine properly balanced while its out to try and eliminate this unwanted vibration and have made contact with a company close to me that balance the Force India F1 engines. Cost is around £300 to do all the moving internals.
However I noticed this today and wonder if this has been my problem all along…….
I'm about to strip the engine to clean it up anyway and this will involve stripping out the pistons and crank etc so it'll seem the right thing to do to get it balanced but I wonder how bad they are from the factory or will it be a waste of 300 notes?
Do I still go ahead with the balancing and or just risk changing the duff mount?
Decisions Decisions….. :dontknow:
Don't tell the Mrs!
Steaming cleaning the block prior to bead blasting and painting..
Bead blasted block re steam cleaned.
Honed and painted
Never noticed the little "VW" stamps on either side of the engine number before.
While baking the block paint thought I'd screw the exhaust manifoild back together..
Out of curiosity I weighed the rods and pistons and there was an overall difference of 8 grams between the lightest and heaviest combinations. By mixing the rods and pistons up I could reduce it to a 4 grams difference. Pucker race engines are within 0.5 grams. I'll see what the balancers say is respectable.
watson said
Some great work going on there in Banbury. Complete underside referb. and now engine rebuild - all before the German trip too. Impressive stuff Graham.
Cheers. I'm hoping to have it ready for the AGM! :?
Who bought the date of that forward :roll: ? :wink:
Must start stripping it soon.
He said he was surprised how bad it was considering its German.
I said at least it was worth doing then!
Below is the certificate he issues. The final tolerances are within F1 spec 8O
I got him to take some photos as he did it and will post those up when he sends them to me.
The weights are shown in grams. mm which basically translates to - if you are 10 grams out 100mm away from the centre of the crank then its 10x100 = 1,000g.mm.
Once balanced, he told me, the crank will only move 0.09 of a micron once spinning above 450 rpm.
cheers keep up the good work
