my mk1 24V VR6
my mk1 24V VR6
I am quite a novice when it comes to engine conversions, how is it that you have installed yours without cutting away at the chassis leg like paul_c had to on his conversion
cheers kenno
alexHxC said
24v? hows that work man
just like with 16v engines, 4 valves per cylinder
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
ashtray said
if you use the right combination of bits out of the vw part bin it fits with out any modification to the leg! just!!!
Agree - my engine clears where the original 0chassis leg would have been. But, it would have been a lot of a squeeze installing and removing the engine. I reckon I've had mine in and out 10 times or more, during the project.
yeah they do seem to have to come in and out a fair bit its NOT easy folks!!
I also forgot to put the the water pump pulley on so now all the mounts will have to come off its just too tight to get it on but it dose clear one on! maybe it would have made my life easier to cut the leg away like you have done
i ment a 24v vr6 lol i thought they only came in 12v?
The original ones were 12V but later ones, basically Mk4 Golf onwards? were 24V. Basically its a later, more efficient, engine, however still with the obvious design limitations brought about by the unequal length inlet pipes. VW did develop a solution to this, but it was too expensive to put into production. It kinda got passed around a bit and then ended up as an aftermarket tuning thing, the "Schrick manifold". Look at ?1300 or so for one, however. The R32 (3.2 litre) is a bore and stroke of the 24V VR6 engine, probably with larger valves, hotter cam and obviously different ECU programming too, to achieve 240bhp (24V was around 190bhp, the original 174bhp as 2.8 and 190bhp as 2.9 in Corrado). The 3.6 litre VR6 as used in the Passat R36 (not available in UK though) is another development again, and uses FSI technology. I'm unsure if they introduced variable valve timing, and when, on the VR6 family (I think 24V and onwards in a basic (allows to advance) form)?
http://www.volkswagen.…/engine-and-transmission/
Oh well…R32 it is then.
the mounts look the same too?
could have that in our cars in a few hours :twisted:
got the drive-shafts rebuilt and fitted all the new brake lines and bias valve fuel lines and pump the other day. Not had much time l been working all the hours, bloody holidays! i was quite happy to spend the weekend at E38 the Mrs wasn't ha ha so is yours all sorted? on the road now?
ashtray said
alright bud? um i don't think its gonna be finished for 4to6 weeks
I've a little way to go too. I'm going to Action but playing it safe with the black 16V.
