mk1 project - shell up custom rebuild- sheet metal work time
i'm basically doing every seam in the bay because i want to smooth the bay only using the bare minimum of filler
if its just for some added stiffness i'd start with the turrets and supension related ones and go from there
sorry don't have more pic's to explain
best of luck
mike
bud said
looking good mr birch, drivers side chassis rail looks awesome! cant wait to see it again, but when its not so cold lol!
see you sometime in june then
bit of an update - been a bit slow working on the car at the minute - its bloody cold outside and you know it time to call it a day when yesterdays mug of tea has frozen over
few more bits of smoothing
drivers side engine mount all boxed in
all the turret seams have been welded up and ground back smooth
rog nipped over for a spot of afternoon tea and to wield the blowtorch while i got busy with the body hammers. - took a few photo's too
can you guess what this bit is for?
maybe now
all welded up and ground smooth - capped the ends of the mounts too
propably never gonna be able to see this work on the final car ( 4 hours+) as turbo will be in the way but i couldn't resist
crap pic but is was ready for a beer at this point
got to get 90% of the bay work done - then send the car to have the bay media blasted before i can continue with the remaining bits i have planned
then its engine fitting time ( want to mock the whole car up and get it running - then fully strip it down for paint
will keep the updates comming
mike
very inspirational.
Pics?
hopefully 95% of people will never notice the changes :twisted:
mainly to the chasis legs + started smoothing the front panel
just trying to keep it smooth and factory looking.
starting removing the tar on the floor and bulkhead for another little idea i have.
hopefully have some updates ( with pics by the end of the weekend)
might be making a start paint stripping the bay
cheers for the comments
supadunc said
cool, dont be shy with the pic's, get em up so we can have a gander.
Yes, please do.
made a start on stripping the underseal of the floor - the combination of a freezing garage and tar fumes didn't really help my cold
mainly been working on little mods to the bay - improving on the factory look - just little details that we saw that didn't look right
not that you can see but there is about 8 hours + in all this lot - reckon few people will notice the changes
added a curve to the drivers side leg where the support for the brake mechainsm used to be - you get left with a odd looking flat section - thats doesn't fit
now mirrors the passenger leg and adds some symmetry
Also added another Rib to the passenger chassis leg to even it up and get rid of a large flat section - ribs now match up on both drivers and passengers side B)
Rog gave us a hand shaping and welding the thing in
before - hideous
after - much better + plated the vertical section face of the passenger side leg near the bumper mounts - removes two lumps that ruined the flow
Boxed in the old small block engine mount - lot of cuting and welding / forming - really makes the chassis legs look more even and solid
finally - smoothed in / capped the wishbone mounts - lower hole left to help drain any water that gets in
just debating now whether / what media to use to get the bay back to bare metal so phase 2 metal work can begin !!!!
cheers for all the comments
mike
yeah pretty pleased with how things are coming along
thanks for the interest
still been grafting on this on and off this past week or so.
manged to get an eye infection from some metal dust that was in there - nice
have removed all the floor tar + bare metalled the bulkhead and started grinding back all the welds on the inside of the bulkhead
they'll be covered up with sound deadening but i want them ground back and filled before
cutting the scuttle out this week - bit of reust behind it and i couldn't be 100% sure i get it all with it on the car
so its coming off fixed up and then put back in
hopefully update the thread with some pic at the weekend
had to get the metal taken out my eye with a needle - and it true mk1 form it has rusted !
bay is looking good - but not too different from standard subtle changes here and there. - thats a good thing
so many hours have gone into the bay and a hell of a lot more to go
eye is about sorted - saturday night boozing helped sort it out
i'm only updating it when there is good stuff to update
should have something by sunday night - if i get a good few hours at it over the weekend
mike
managed to get myself a nice eye infection from some metal dust - typical mk1 the metal rusted too making it worse.
i'm currently still too drunk from last night to do much work today so i thought i'd post some pictures
ground back all the welds on the inside of the bulkhead - will be covered up with carpets etc but needed to be done so its looks like it came that way from the factory
scraped all the tar up of the floor too - real fun job that was - still need to remove the remains but i'll treat myself to that another day
seat rails got the chop so i can weld in fixed bars and run the seat real low - giving me more head room with the cage
scuttle panel had some surface rust underneath and had rusted through in one place - i wanted to treat it all properly - so it doesn't start again in a few years time
so figured it was best if scuttle came off - fixed and replaced
all taken down to bare metal and etched
need to smooth a few bits and do some repairs and its ready to go back on
got some bits at the laser cutters so hopefully be able to get some engine mounts fabbed up soon and get cracking with a few bits
so much to do !!!
mike
