More work on the little black GTI...
chudd said
paul_c said
chudd said
And you will be pulling that with ?
Another car?
A Golf ?
You need a fairly big/heavy car to tow a car + car trailer, so another Golf simply isn't heavy enough (even a Mk3 or Mk4). So, its my other car which isn't a VW.
Life Member
From within bellhousing (I'll now need to check out the clutch etc):
From above looking at diff:
From below looking at diff:
Web Team
Web Team
ew said
Do you reckon it had too much power going through it or general wear and tear?
The diff pins are a common weak spot so it was probably these which went. I guess its a combination of the wear/tear, then the high power plus grippy track, which put too much force through the diff. I accidentally did the first burnout of the day in 1st, (the second one was in 2nd, as usual) and maybe this overloaded the diff? I don't know….
mk1 golf gti in porsche ocen blue and polished porsche 7slots
I was watching the action on Sunday afternoon after the rain had stopped and a late….ish (circa 1999) road going Alpha launched off the line and ground to a halt about 10 metres off the start with a big pool of gearbox oil underneath. I imagine he did something similar.
It was most amusing as it was in front of a load of VW fans! I imagine the grippy track and an over entusiastic left foot got the better of this road going car.
I would have loved to have seen the Harry Enfield charecter going up to him and saying " I don't believe you wanted to do that!"
I bet he needed it for work on Monday to.
The engine is running a bit funny now (will hunt and stall during idle, otherwise ok) and coincidentally, while I was underneath tightening up, an M8x20 bolt fell off the car, so I suspect these 2 issues are linked (I reckon its a bodged plug in one of the vacuum lines). Also, the reversing light switch doesn't work - jammed on - so I'll swap that over too.
I also did a trial loading onto the trailer and it scrapes a little (the front spoiler catches), so I might be 'modifying' the trailer a little bit so it goes on and off smoothly!
At VW Action we did some night racing which was very cool, but still I haven't been able to better by PB quarter mile time. However its performing consistently at around 14.4 secs. It doesn't make sense that lower ratios would give less performance, so I think the issue is that the power tails off the higher up the rev range and so with the previous transmission, the 4th gear stretch was more usable and gave a better time.
So now, I need to decide what to do and I'm in a little bit of a dilemma. I could spend a bit more on it with a 'package' of improvements such as:
- Rolling road session to discover properly where my power band is, followed by some calculations to give me the optimal gear ratios, then possibly swap the gearbox
- Maybe even more weight saving?
- Slick tyres up front (2 of my tyres are now worn out after 60 miles of drag racing and around 1500 miles on the road).
Or I could put the bumpers, trim, interior etc back onto it, raise the suspension a bit and simply enjoy using it as a normal car.
There comes a time when unless you spend vast amounts that that is it .
You may have seen me mention the fastest Golf MK1 on the planet ? Grant Parkers Audi powered 5 cylinder , well it seems he is stuck on 10.2 quarter miles , terminal speed is over 146mph .
Like you said Paul …………..
Cheers…………..
Cheers…………..
Well I guess the long term plan is to finish the VR6, get it performing properly (possibly also with a couple of runs down the 1/4 mile) and see which one I prefer the most; then sell the other one. After all, no point having a fleet of modified fast Mk1s is there?
If I had more money (and time and motivation and skills….) I'd want to build an even faster car than even sticking a VR6 in, well maybe one day I will do that and beat Grant's car?
Over 30K in that build 8O
Next build is 1000HP in 1000KG Audi . I think any top performance is now down to how much money and technology you can throw at it not what you can achieve Diy at home .
If you read any old VW Mag from about 10 years ago any MK1 doing a quarter time of over 15 seconds was considered awesome , you have broken this .
my aim is to get into the 13 seconds mark with the cabby then build something silly like a mk1 with haldex and 16v turbo 600bhp would be nice :mrgreen:
Firstly, the trims were carefully removed then rubbed down with 80, 120 then 240 grit abrasive paper. Then painted in primer, wet flatted with 600 grade, then painted with Mars Red No.1 and clearcoated too.
Here are the trims being painted in primer, note their mounting on an old grille kicking around.
While it was off the car the plastic sections were given a thorough clean
Ready to assemble
Back on the car
Now it shows up the rest of it! Better give it a wash…..
