'82 Golf GTi 16S (Oettinger)
This one is for you, courtesy of Ruediger Voelkner (MD) Oettinger Performance GmbH.
He asked me today if I would give you a key ring next time we meet.
He read the thread this morning.
Life Member
That means so much to me
Vielen Dank Herr Voelkner!
Tonight I swapped over the starter from my Lhasa GTi and she fired up first time. I had strange symptoms - the old starter tested OK out of the car when connected directly to the battery of my Vectra. Did the same on my fully charged 16S battery and the pin fired but the motor didn't turn. No voltage drop between starter and battery but the car would not jump start from the Vectra unless the 12V lead was connected directly to the starter terminal. Somehow the starter was drawing a huge current that the Vectra could cope with but the 16S battery could not.
Bad news is I still have a hot start problem despite changing injectors, WUR, pump, filter, fuel distributer, accumulator, check valve, cleaning out tank…
Will test fuel pressures again at the weekend, I am suspecting a 2nd dodgy check valve that came with the new pump. On a brighter note my brake pedal is now rock hard after bleeding the brakes - almost went through the windscreen! LHD brakes 8)
Life Member
Since the last update she has had:
- new VW starter motor
- accelerator cable and pedal bush
- 16V WUR
- new metering valve gasket set
- water pump and thermostat
- expansion tank
- gear linkage relay lever
Life Member
dubboy said
Lost all coolant from my water pipe on the way home from Festival aaaaaaaargh Thank you McDonalds for a few jugs of water to get me home
Were they large jugs or supersize?! :wink:
When at school, I was never that interested in studying French, so my resourceful parents, bought me french car magazines to read.
I have a French GTi magazine from 07/82 where they test several standard and modified cars,,one is a white 16S with what appears to be a mild Zender kit on ATS cups?
I hope the restoration goes well, are you taking to many shows this year,,,it would be great to finally see a 16S.
cheers.
1983 Campaign, BRMotorsport152
Life Member
clubsport said
Wow!…what a great Gti….I have never seen one of these in the metal..
cheers.
Probably the car you saw was a 16S with the standard BBS kit and ATS Cups.
Will be at a few shows, here is a pic from Spring Festival
<a><img></a>
Life Member
Guest user
Life Member
hi raj, was just reading up on oettinger mk1's (just googled oettinger golf mk1) and it was saying they only came in two colours alpine white and anthracite grey LP9V, only 1250 were built to 16s spec only available in france and switzerland
http://www.faltdach.net/vwgolfmk116s.htm
GOLF MKII GTI 8V - sold
GOLF MKII DRIVER - ex took it
GOLF MKII GTI 16V - scrapped
JETTA MkII GTI 8V LMT EDTION
Marc
Life Member
zambeaky said
The 16S was only available in 2 colours Alpine White and Black Metallic. Black Metallic was unique to this model (not to be confused with Anthracite Metallic found on the standard GTi).
I can see I am going to have to keep an eye on you and my keys!
Life Member
MY80 GTI | MY07 GTI | MY10 S3
i too own an oettinger
being french help she is in much worst state than yours but on the way to be much nicer then it s actual state
black too
regarding your hot start problem did you check your cold start sensor as mine was stuck on all the time and flood the engine when hot
i m in the process to upgrade my engine will keep you posted
Romain
oettinger
loveFree forum : Oettinger 16V Group
Congrats
