2.0l 16v charged - track action vid 7/9/09
(In Topic #97036)
the specs so far are:
1983 GTi built for track use and summer B road bashing.
Engine:
9A 2.0 16v engine
modded S2 inlet manifold
cosworth injectors on a mk4 fuel rail
megasquirt fuel injection ecu
Eaton M62 super charger on custom bracket
big front mount intercooler
mk3 16v throttle
windage tray to help control oil frothing
Suspension
FK coil overs, Polished adjustable front top brace, OMP lower front brace. poly mounts all round
Wheels
Road wheels: Compomotive MO's 7x15" et35
Interior
Fully stripped out,
Safety devices rear cage,
Cobra Monaco S seats
Ricco Racing FIA 3" webbing harnesses
Gauges fitted in radio hole.
Exterior
De-bumpered,
Aerial removed,
rear wiper removed,
Name stickers on the rear side windows.
Zender spoiler
Plastic windows
Brakes
MK2 16v master cylinder and servo
Golf mk3 GTi caliper with spacer brackets
G60 280mm discs
dot5.1 fluid
mk2 rear disc conversion with mk4 calipers
grooved discs front and rear
yellow stuff pads
so what you all think?
mobile welder wirral here
http://www.volkszone.com/VZi/showthread.php?t=366253
i guessed that by looking at your sig lol 8)M7R said
but i was still able to beat a porsche. :twisted:
Whats it cost to go round donny? Sounds like fun.
www.cw-se.com
"Video et taceo"
"Video et taceo"
Nice car BTW!
1983 MK1 PIRELLI EDITION
Alpine White LHD ("SOLD")
On the newmans, I love it, loads of low pull from 1k upwords, gets to 2k and it goes a little faster, gets to 2500rpm and the it really starts right round to 6k! it should be better later in the years as i think my metering heads a bit past its prime so i may get another as a spare and look at cleaning mine out to see if that works, then if not whack another on.
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
also on the plus side - I HAVE BRAKES!!!!!!!!!!!!!!!!! 8O :twisted: my bargin master cylinder from the scrappy off a audi 80 has finally given in to me!!! i had to get a eazybleed thing that conects to the tyre and run it a little higher than the 20psi it says :twisted: but all the brakes have now bleed, and all 4 outlets give fluid so ive plumbed in the brke light switch to one of the spare ones.
the only issue now is that the adaptor brakes are STILL catching my discs!!! :evil: so they need another touch with the grinder, but while they are dragging they are making a groove on the surface (luckly at the very inside edge of the disc) and making pushing the car in and out on my own impossible! but hey ho, suh is life.
also is it weld or bolt in fia all the gumpth please :mrgreen:
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
does it show im happy! i have finally been able o get the 280mm brackets to clear the discs, its lefta few marks on them but shoud be fine.
I have also just sold my wheels so im off tomorrow to order my fancy new ones 8) :wink:
Roll on summer!
I got my self some Compomotives for a good price, went tp pick them up all was fine and dandy, they were et25 so should fit and clear the brakes…..nope. the et is thanks to the spokes being in the middle not near the edge and having a big spacer built into the hub, so this gave me issues. the caliper now touched the back of the spokes. so with a 5mm spacer they clearerd……..just, (this will get better as the pads wear down) they were now only catching on the top of the caper touching the rim.. so this was sorted with a angle grinder as the wheels had been repainted, and I had painted the caliper it was all too much…..I skimmed the top face of the caliper to remove the paint and whisper of the surface of the caliper and I now have fag paper clearance!!! ((this will increase as i wear the pads down and in future I will skim the pads to start with)
Im still not sure i out of the woods yet though as the tyres have 50 profile side walls not 45s so I think they maybe too tall, but we will see when it back on the road, plus the wheels are an extra 8mm further out too..
on other news I tried pressing the brake pedal today, and its soooo short, these brakes should be brill with the new master cylinder and bigger calipers 8)
I will get some better ones soon when the weathers better and I get it washed and rebuilt with the duck bill etc,
I also may get it started today..
OOhhhhhhhhhh yyeeaaahhh!!!!
I also finally got round to emptying the boot ops:
Not driven it yet though as still no battery and also the pads need more taking off them so the clear, but nearly there.
Will have to meet up once mine is done. Check out my project pics.
Duane.
Yeah big brakes!!!! and clearance!
what you all think?
but you've got away with it :wink:
tempted to find a back box that's shorter?
Looking good though 8)
