Anyone TDI'd a mk1..?
(In Topic #96775)
Chairman
I seen that purple one a few months back in PVW just wondering if anyone actually owns one as I'm currently looking about to which conversion to go for and I'm steering towards a 150 pd tdi.
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
ive thought about this also but it would be quite expensive to do i think. would be nice with all that torque though!
bert on here has a tdi in his mk1
Need your console repaired or mods done? drop me a pm
Chairman
I'm currently awaiting a couple of quotes, apparently it's no more expensive than the 20vt but we'll soon see, if it's not too expensive, then I may be sending it away to be done.. watch this space..
Follow us on:
Follow us on:
Bert's is a TD, not TDI. In other words not electronic injection. No doubt he'll be along soon, will probably post a pic of the engine bay or something.
ah right, my mistake
thought the i just stood for intercooler? :dontknow:
both mine and bert have the early mk3 aaz idi td engine which is a simple 1.9 td good for 250 bhp with the right knobs twisted!
the late tdi engines run with an ecu and electronic fly by wire throttle, hydrolic clutch and a cable change box. i did look into it and for what i wanted the extra hastle seemed unessery. i plan to heavily tune mine when the times right for 150-200 bhp which should be easy to achive without putting out to much smoke!
a tdi is possible if you have enough knowledge of how they work. or plan to build a m-tdi pump a good place to read up on it all is www.vwdiesel.net theres a tdi and idi section for you to explore
hello!
Chairman
Cheers rov716y very helpful.
I'm doing for more reliablity than anything, and it's my daily, hence the diesel engine, I've debated buying another car with the money I'd spend, but I just can't see myself in anything else.
Follow us on:
Follow us on:
Having had the engine out of my Tdi Caddy van, I'd say it wouldn't be mega-hard to transplant it into another car (in terms of the wireing at least). The PD engines have more electronics - the non-PD (ie, 90 / 110 bhp models) are a lot simpler and very tuneable. Mine has cable change gearbox and hydraulic clutch (same as a Mk3 Golf) so no fly by wire or anything like that. In terms of 'tunability', with turbo from a PD150, bigger injector nozzles, and a remap I was estimated approx 200bhp. I won't be going that wild though !
I'd say buying a damaged car as a donor would be the best way. Tdi Ibiza / Cordoba / Leon or Caddy van probably the cheapest option.
Chairman
That was the orginal plan, I don't have the knowledge to do it myself, so I'd be paying a specialist, so I was gonna go dash conversion too.
But there's a company called megasqwirt that do the wiring looms, and I believe the ecu map, to make sure you don't need to key to start the car ect.
Follow us on:
Follow us on:
mine came out of a mk3 golf estate on a lreg mot failure (rotton) got of ebay for ?150 with a fully serviced td in her. never regreted it. a td you can have in and out in a day a tdi with wireing is a bit longer. if you want a car wqith a bit of poke and still reliability and fuel econam the aaz is the way foward simply by modifying a pin on the pump you get a good power increase and still get 55mpg out of her.
hello!
talk to bens cab about megasquirt, his friend is a agent for them iv juist got a system for a 20vt off him and so have a few on here
ggive a pm see if he can help you
although weve yet to do a system for tdis i dont think it would be a major problem i was thinking of doing this for my van that way i can run a tdi lump
ill give eddie a ring and find out the ins and outs :wink:
old skool rotary ones can be run on cooking oil / deisel mix, where as PD cant, but the PDs will give better economy and more power.
when the time comes in a couple of years and i can afford the insurance on the mk1 with a new engine im seriously thinking of a 150pd power, as so long as you have a front loom it shoudlnt be "too" bad… it needs more leccys than a rotory but should be do able. then with a plug in chip i should have a good 180plus bhp and shed load of torque plus a 6 speeder for crusing when needed.
paul_c said
if it was an alfa you'd need sweep as well for the parts.
novocaine said
And if it were a cabby, you'd need Sue
i bow to your superior knowledge sir paul.
Tuned Tdi's seem to be even worse on the 'sooty' front :
http://uk.youtube.com/watch?v=01Gp0Tdy_Kg
(caused by bigger injector nozzles methinks)
