HELP!! 1.8 mk1 wont run.
(In Topic #96534)
I have just bought a mk1 gti, it has been sitting for just under a year. I gave it a full service when i got it. I drove it on sat for about a hour then it started running strange. I ended up having to put my foot all the way down for it to go anywhere. Had a friend do all the timing for me checked all of the leads coil, just changed plugs. I also put another new fuel filter in last night thinking it may be clogged. Now the car will start rev up then will die striaght away. If i get it going it just back fires and is really hard to keep going. Any ideas? any help would be great.
Thanks alot. That hour was so much fun!
also may be worth looking in the fuel tank to see if thees any rust could be blocking the pump up just giving you enough fuel to start
if all that is ok try the accumilator
the amp controls the spark although it may seem good doesnt mean it is if you get my drift these can be got from gsf but not cheap iirc
go fishing first report back :wink:
Ta
P.S When it was running crap it was also misfiring.
In fact, do a fuel pressure test, this will tell you straight away if there is a blockage issue!
subwestyjon said
Do i need any special tool for that?
Yes you will, but its the "gold standard" for checking fuel delivery.
all pulleys hit there marks
the rota arm point to plug number1
the leads are on the right way 1432 iirc
if the leads are on wrong it will run but wont rev and will backfire i had this problem with a car i got once :wink:
