Cabriolet Restoration
what about 16v turbo they are pretty good engines to have depepnds on your budget
the car looks ace by the way
yannyboy said
What parts to you need to turbo the 16V. What power output is achievable and what needs to be done to the standard 16V engine. Is there any threads for this conversion.
clubgti do a search for the wolf R username toyotec he has a 280 bhp one running megasquirt amazing bit of kit he will be able to give you a complete list of bits needed
18T with ko4 is where you want to be i guess 260 bhp easy its all down to preference and cost i guess
g60 is ok but im not a lover of chargers tbh when they go bang its ?600 to get it repaired least with a turbo they are not to bad price wise
you could always start with an ABF lump standard then charge it later ?
More updates soon.
Why do you want to change the dash, the mk3 looks good.
Graham
(Boraboy on most other forums)
Cabrio GTI Now in Lhasa Green with running 1.8T AJQ on OEM management.
Coming to bits again for more mods after reading to much on here…
Oh yeah, and a Golf V GT TDi
Since I am planning to fit a later dash, I might possibly transfer complete loom from the Mark4 Golf and run the engine on standard ECU.
These are the rear brake carriers. As you can see from the previous photos, my syncro had rear drums so I wanted to uprate to discs. Unfortunately the carriers were only found on vehicles with syncro running gear which makes them almost impossible to find. I ended up getting them from a guy in the Netherlands. Once the carriers are fitted, I can the fit the calipers from any rear disc set up. Might go for the Mark 4 aluminium calipers.
I will post more at the weekend when I get the rear suspension on.
Powerflex bushes.
Will try and get rear wishbones and rear diff on soon.
Wishbones next.
also the beam mounting points do the line up with the mk1 bolts ? looks very good
:wink:
The rear sill section does need to be cut for the rear beam to be fitted.
Found this pic which shows rear sill section a little clearer.
with my hydraulic press.
After about an hour I came to the conclusion that if I can press these bearings in, I can press any bearing in.
Trial fitted the wishbone
Unfortunately I have found that my rear coilover won't fit. It's too long so I need to find a different coilover. I was wondering if a coilover from a syncro/rallye or a universal might fit. Any suggestions?
