HELP!!!!! Cabrio keeps cutting out.New Member!!
(In Topic #92408)
Help!!!! cabrio keeps cutting out.Newbie!!
Its not the ignition amplifier either.Any thing else you can think of?
Alarm is disconnected when i bought it. and when it cuts out after a few miles it has no fuel in the inline filter so i used to wait for a while and start her up again and would only get a mile or two b4 it would cut out again.Now it wont even start now,it will try2. spoke to mechanic there who has the car and he said there is no spark from coil lead! but we did swap over coils and amplifiers and still no spark to ignite the fuel.Any suggestions?? car is perfect in every otherway.shame to be off the road!
Thanks again Chudd.
Life Member
Turned out to be the wax stat (as he reported). I don't know if thats right/if thats what its called/ or if it helps. But it might!
Dan
Hi Cal Brand new tank fitted and fuel filler neck also brand new and new fuel lines.Car went well 4 few miles when i had replaced them and just cut out again and hasnt started since.Honestly ive tried everything possible and fitted all orignal new parts,The tank was dirty!! cleaned the sender intank also.
Thanks again for speedy replies
sounds like a lovely spec cabby…….nice colour too..just need to get it running now :wink:
Life Member
I'd forgotten about that filter problem. I had a Mk2 in 1990 and ran out of petrol, muck got sucked through then it began to cut out. Got worse as the tank emptied and the fuel pump buzzed. I was the filter in the tank.
I'm always a bit paranoid when I hear the fuel pump on the Cabby buzzing… now I remember why!!!
Dan
Dano it aint injected.its 1.8carb type and the fuel pump lifter and fuel resevior and inline filter have been changed 2.All new parts.along with new tank fuel filler neck and new fuel lines.and was topped up with new petrol.When car did start it would tick over 4 ages and it was when i drove for a few miles it would cut out and took ages to start then would cut out again and again.but each time id noticed the INLINE filter was empty!! Thats why i had suspected a fuel prob!! Then i replace dizzy and started to check all the electrical bits.Fuse box mayb???? :twisted:
New Dizzy was fitted also.Car getting picked up 2moro and getting transported over to a Bloke who knows how they run!! and is Enthusiast!
Fingers crossed.
Again Thanks 4 Help mate.
wolf said
Hows it going TOP?
Fingers crossed.
Please let ,me know how you get on….I've just bought a 1991 Clipper Cabrio Carb…and it starts great, runs for 2 mins, then starts coughing and spluttering….won't hold any revs when under load. I stop and pullover for a couple of minutes,and its ok. Does feel a little lumpy, but does run.. I need help too!!
eventually got it sorted and runs well now :wink:
was a number of things but think TOPs suggestion was the main PROBLEM :roll:
TOPs suggested as follows:
1 of my mates have had this problem on carbed mk1`s, and on his it actually turned out to be the little filter sock in the tank all blocked up and starving the fuel off, it would run for a few miles… stop……wait 10 minutes and it would run again………sometimes it ran fine and others it wouldnt start!! he changed the sock (like a little tea bag sausage thing) for new one cleaned out his tank and it never did it again, maybe thats the problem? its cheaper than the other stuff you have done!
Anyway Mechanic Cut that little filter off and said that was common fault.
Hope this helps :wink:
