rollin road RESULT!!!!!!!!
80bhp :dontknow:
rebuild in progress....
closest anyway
would mind sticking min e on the rollers soon g-tech pro says 196 bhp but im pretty sure it may be a little less :cry:
bring him to the strip mate lets have a play :wink:
was gonna put a few piccies up but no one will believe me so didnt bother!!
cabriaulait said
ive only ever seen the car in the garage…….
he must be a trailer queen then :cry:
waits for pauls_c to give the correct term for that
cabriaulait said
wheres paul c :wink:
Well done mate, nice power figures. Its interesting analysing the graph, beyond 5000rpm torque takes a definite downward dive. In ideal conditions, you'd expect the torqur to gradually decline as revs increase (due to increased frictional losses as you rev higher). The sharp downward curve suggests you're leaning out towards the top end. I saw the same on my rolling road graph, in fact I posted it on CGTI which sparked a good debate on the optimum metering head. (The conclusion was, the stock 16V metering head was good up to around 180-200bhp).
Other options to check out are fuel pump and filter(s). If you have another run done, ask the guy to put the wideband lambda probe into the exhaust, so you can see the plot of air/fuel ratio too. Ideally you're looking for 12-13 (14.7 is stoichiometric, you achieve better power at the expense of higher emissions and fuel consumption, at lower AFR).
To avoid many trips to the rolling road after changing each part, I have bought a wideband lambda probe and data logger (Innovative LM1). Its just stuck in a Parcelforce depot, shouldn't be too long until I receive it. This means I can make a change and see the effect. My rolling road results showed that the car is all fine, except for the fuelling at the top end (similar shape to your graph).
did anyone find out weather the 1.6 metering did infact help at the higher rpms or is it just myth?
bens_cab said
see yet again dave i feel the need to tell you i told you so 8)
Until someone shows a dyno plot of a car with it fitted, its myth.
thinking about doing the shim mod next with audi wur rather than changing the metering head
ill test fuel pressure tho, filters newish but have considered using the later cabs larger one next time i change it
not gonna ask about the screw then :wink:
so a pump that can outpump 4 injectors at max revs?
maybe a merc one??? :wink:
cabriaulait said
and i believe my injectors max at 49 whatever it is lb/?
Mechanical or electronic fuel injection? If we're still talking about K-Jet, then yes you can fit a fuel pump for a W123 or W124 (6 cylinder) 280E, 280CE, 300E, 300TE or 300CE.
