Back From Garage! Run out of ideas!! Please HELP!!
i am getting little pops from exhaust yes… wats this mean??
1, loosen the dizzy get a timing light and double check again try turning the dizzy slightly either way and see if it improves
2, being a cab you will have a lift pump in the tank check its working and theres power ther
3, go fising in the fuel tank with a big magnet
4,my old favourite fuel acummilator have a look and see if it wet on the end where the screw is
and if none of these are the fault scrap it
I got it back from garage and they said the mixture is way out, also i have a split in the rocker cover T pipe, and the rocker cover gauze is clogged up with oil!!
so i will be changing the pipe and cleaning the gauze then getting the mixture set up propperly then fingers crossed she will be alive!!
This like a big game a bunch of use buzz in and try our luck.
rite still not working i am in the process of changing both the fuel pumps atm to see if that helps!! one was making a rather weird noise sounded like it was being over worked!!
if its not that then i am deffo out of ideas!!
wooders said
sounds very much like low fuel pressure. could well be fuel mixture too.
if you do not have an exhaust gas analyser, try it the old fashioned way. at least it's it's free and may help solve the problem.
there is a tube sticking up on the metering head, between the rubber egg boot thingy and the metering unit (bit the fuel lines are attached to). using a long 3mm allen key, very gently insert and turn anti clockwise to lean (i'd go this way first) and clockwise to richen. important to try not to apply downward pressure while doing this. if you go one way till it tries to stall, note that point, then go the other way until it does the same. go back 2/3 towards lean. rough but it should be a whole lot better if that is the problem. before you do this, out of curiousity, unplug the cold start injector and see if it makes any difference.
worth taking the plugs out and seeing if they are grey/black. clean up and pop back in.
if that works, happy days, but it does sound like fuel pressure. are you getting pops from the exhaust?
I will be trying this tomorrow on mine, if it works, I will PM you a slice of my birthday cake.
Sorry for the thread hi-jack BTW.
the system is pressurised tho!!
i will try the mixture thing tonite too!!
thanks
Good luck with yours mate.
RobinM said
It's worked for me
where's my slice of cake then?
i checked my injectors, only one was working propperly (may have even been over fueling), the othe 3 were either dribbling or only half spraying number 2 injector continues to spray petrol out for aroun 2-4 minuites after the pump is turned off!!
i have ordered some new injectors and fingers crossed this will solve my problem!!
Waht you guys think?
