i need a fifth gear!!!
The code should be on the top edge of the bellhousing.
thanks for all the help dude.
The 8P is a good choice of box. I've got a GT box, which is great for fast road stuff but no good for cruising. I've now got an 8P to try, but haven't got the time to swap them over.
i got hold of a 5speed box. mine was a 5speed box from a 1.3 mk2 golf, but i believe you can use mk2/mk3 polo 5speed boxes 2.
As far as modding 2 fit it in goes, yes….you will need to weld.
all i basically did was just used the original gearbox mount from the car, cut the bottom half of the mount off, and welded it 2 the top of the mk2 golf gearbox mount:
also, the rear mount had 2 b modded slightly, had to cut a lil slit in the rear mount for it 2 sit properly:
advisory, change the clutch, only cheap from GSF for like ?60, and doesnt take to long to do.
after its fitted, its just a matter of gettin all the gears. take off the rubber thing around the gear stick, and you will see 2 lil white plastic things held on both sides of the hole. pull them off as you wont have enough movement to select 5th and reverse. to be honest, i even had to bend the hole abit wider to get 5th and reverse for some reason .
i also put in a repair plate on the bulk head as i've erd they r prone 2 bend ?
hope this helps.
PM if you need some help.
thats how ive done mine, good work
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
mk1john said
chris, where did you get the clutch cabe repair plate from? jools182 is looking for one; see post in bodywork and fittings
GSF my friend. Part no. 171-898-152, ?10.28 with VAT
i've got the 5 speed box in my driver, 1300 MH engine from a mk2 polo, never taken a look at the gearbox mounting in any great detail, might bob down for a look in a bit
good job there
i loved that car 2 pieces! really wanted his wheels, and the interior is pretty dam lush
i have many saved pictures of your car on my computer. ha
if it is the same car
full conversion shot inc. weber carb
hows morning starts with that K&N filter? i had a filter like that once, but made my carb ran awful, i just ended up using the original stuff.
Whats the movement like ? Any " pulling " around that bolt hole ?
Real golfers don't play with clubs
the 5speed box mounts is very similar 2 a GTi 5speed box mount. the bolts go tru it side ways, not straight down. hence why you need to do some welding 2 that mount 2 make it fit.
