What jiuce are you drinking?
Tian wrote…
I don't care what you run,I buy the cheapest fuel as I drive past. I honestly don't think it makes that much difference in an 8 valver of this vintage. My 20 Valve Turbo Volvo does drive better on high octane but then again its a modern multi valve engine and should. Don't waste your time going for extra power from your Golf though, waste of money.
If timing is set to VW specs, Mk1 GTI's require superunleaded (high octane) fuel to run properly. Ordinary undleaded octane rating is too low and you risk pinking etc which over a time can cause premature engine wear/damage. You'll actually find most modern cars (even performance) can cope with variable octanes as the ECU can adjust the timing etc to compensate.
1983 1100 C
1983 1100 C
Rach_GTI said
The original sticker thingy inside the driver's door shut actually specifies that you should use at least 98 ron…
That's a good point. I'll have to check my owners manual when I get home.
Obvious really.
Tian :roll:
Last week I did 340 miles on 50 litres - let's see here:
50 litres: 50 / 4.54609 = 11 gals exactly
Gives a nick under 31mpg on combined cycle - A roads, B roads, motorway and some urban which I think is exactly in compliance with manufacturers spec.
MP
