mk1 caddy engine swap
(In Topic #87666)
The good news is that you're starting from a diesel, which means the engine mount is in the right place. You'd also need a transmission, since the diesel one will be hopelessly overgeared. And is your diesel a 4 speed or 5 speed? If yours is a 4 speed, you need to weld a bracket onto the steering rack into a slightly differnet place, or swap for a 5 speed rack (I think).
turkish said
do you know any good places to get mk1 bits, all the breakers round here got loadsa mk2 bits but not many mk1s
Go to one of the major shows with the facilities to take away an engine, etc. Traders hate having to load up heavy stuff at the end of the day, so they'll often accept a good price for stuff.
Alternatively there's at least 3 Mk1 specialist breakers, and loads of VW breakers.
Cheers,
Mark
I have assumed it's one of the round front type Passats as I'm not sure they did an 1800 injection in a Passat prior to this (?) I'm pretty sure the older, 'powerful' Passats used 5 cylinder 2.0 engines.
Cheers,
Mark
m6m62 said
Yep - I think Wooders is right about the manifold. Maybe an opportunity to buy an aftermarket tubular job from somewhere like Ashley. If on a budget, you'd get a 2nd hand Mk1 exhaust manifold easily from someone who's put a tubular one on. Just couple it to a Mk1 Gti downpipe and there you go.
Cheers,
Mark
Yep AFAIK the 1800 injections were B3/B4 era, before then it was inline 1.8 carb, or 2.1 (5 cyl) injection. And then after, they went over to 20V (1.8) inline (amongst other engine) just like the Audi A4.
