GTI Project #2
Secretary
GTI Project #2
I have also picked up my rear beam and anti roll bar from John at Dubblasters. Its been blasted and powder coated, looking really good (pics to be added).
Secretary
I have also removed the rear beam and fuel tank. I thought that i was about there with the shell but now i have found more rust on the rear O/S where the beam fixes to the chassis, what a bummer. I will have to get in about it tomorrow.
Sorry there aint any pics, but once i get started i forget to take some. I will try and get some posted soon.
Secretary
Secretary
Secretary
Anyway I chuffed to bits, I spray painted the underside tonight with POR15. Only problem is, I should have worn gloves, after using thinners, swarfega, Cif and a scrubbing brush my hands are still covered :redfaced:
Not long now before i start to put the running gear and new brake and fuel lines on. Feels like Im getting somewhere now.
foxy
Secretary
Secretary
Anyway I have put 2 new wishbones back on to the car, all fully poly bushed. Also put the front wishbone on and cleaned the front hubs and hub carriers up, ready for a couple of coats of POR15 (if it all hasnt cured in the tin). Ive also got the front wheel bearings to get pressed into the carriers.
Just added another job to my list I was trying to fit the backplates and wheel stub axles onto the rear beam (which was suspended from the garage trusses) when i dropped one of the stub axles onto my already prepped front N/S wing which i had stupidly left lying directly below. So there is now a small dent in it that will require some attention.
Hopefully have the car off the spit and back on its running gear so that i can get it prepped and painted.
I will try and spend some time doing the pics. promise :redfaced:
Secretary
Anyway I have a new determination for 2012 to be the year of completion. I will do my best to get some pics up soon.
Hope you all had a good new year.
Secretary
This was the front of the N/S sill
So i cut out the rust, tidied it up and fitted some new fresh metal
Looking at the dates on the pics, this was all done in March and April 2010.
I also decided to weld up and fill the holes and swage line for the bottom sill trim. The reason for this being that someone has fitted a new sill on the driver side and has obviously fitted a non GTi sill, i.e no swage line (is that the right word? :dontknow: ). So i obviously wanted both sides to be the same.
Also note the axle stands holding the car up. That was obviously before I got this
Best thing i have purchased yet. Should have bought one months before I did.
Secretary
my newly built garage (well it was new in 2010). 10m x 3m floor space, perfect for working on the car.
However the next thing that i started to tackle was the O/S rear axle mount. As you can see it was a bit goosed
So it was a case of again cutting out the rusty old metal and fitting new, prior to fitting the new panel
I stripped the threads on the 2 bolts also, so they had to be cut out and replaced. I wish I had read Hairy arse's thread before i did it, as i didn't realie that you could get access to the bolts from inside the car doh! :redfaced:
I gave it a tidy up, treated the metal and applied some red lead paint. Then welded in a new piece of metal prior to fitting the new panel
I then welded the two new bolts to a piece of metal, slotted them into the existing holes and welded them into place before trying the replacement panel for size
then i painted everything with more red lead paint before welding the panel in to place
Secretary
Secretary
The bolt sheared off 8O . I then had to drill out the spotwelds on the box section and remove it to allow me to get in to cut out the rusty metal around the sheared bolt.
i then welded in a new bolt and welded in new metal
and then red leaded the new metal in preparation for replacing the box section
Secretary
and started to clean off all the black gunk off the underside
however when i did this i found a couple of rusty bits under the box section under the passenger side. So i had to drill out all of the spotwelds on this side and cut out the rust.
then welded in more new prefabricated metal
Then once I had the underside repaired and cleaned off
I set about spraying it with a couple of coats of POR15
Before I rubbed it over with a scotchbrite pad and gave it a couple of coats of Mars red synthetic paint. However I obviously didnt take any pics of this :cry:
Secretary
Secretary
and the front wheel arch with the coilovers fitted. I painted all the wheel arches and the underside with 2 coats of synthetic mars red
