1100cc running problems
(In Topic #84961)
i have had new plugs cables and fuel filter and air filter to.
sypmtoms are that i have a serious lack of power and "judders" notice a few posts about this but a mojority tend to be carb related.
the plugs keep goin black but is here any toehr reason other than running to rich?
realy need to fix the problem as its using alot of fuel and i can smell it also.
what else could it be other then the carb? HELP!!!
cant afford to keep taking back as its twenty pound for half hours labour.
thanks
so i took off the distributor ( making sure to make its possition in relation the the dizzy flange and cylly head and also rotor arm orientation ) and cleaned her up….first changed the contacts…take note that set up correctly needs the dwell angle setting up - but i simply used a 0.4 feeler and as the distributir is off the car it made it easier to use this method than on the car….so i got it near enough bag on…
then i changed the condenser which is simple enough…
then put distributor back on re-alighning the makes i made when i took it off….
no she starts first time - no judders and i dont need to run with the choke out at all once engine is warm ( and i use a KnN filter too )
i did then have to lower the Co mixture down abit to - but i used a Co meter my dad had for that.
hope this helps
PS ppl say invest in electric ignition and get rid of points as they hassle - have a look at lumenition optronic or magnetronic ignition….
may do it myself
have you got a link please for the site you got your parts?
ps i may get the parts and print this out and hand it to my local volksworkshop, as i am not sure of how to do what you just described about 'dwell' etc.
i take it your cars spark plugs were gathering soot to?
thanks again
the only thing is make sure of the distributor make first - bosch or ducellier.
iv got a 1.1 c formel E and its bosch - iv got some photos of mine on here if you wanna know what mine looks like
The Mk1 Golf Owners Club
good luck - if you need any advice just ask…. sure you will see the same results as i did…my car was nearly un-drivable with judders and cutting out whenever i stopped…was hard to start to and cained petrol
good luck and let me know how it goes……
ps if you aint got a work shop manual its a good idea to get 1…try ebay but make sure its for the small block (1.1 and 1.3 ) and not big block and GTI
iv been looking for 1 since i got mine mk1 5 months ago - no joy so im going to simple service my solex.
i think when u have changed the points you will see how much smoother the car is and realise it wasnt the carbs fault at all…
this is the 1 you want
http://cgi.ebay.co.uk/Mk1-1974-84-VW-Golf-and-Jetta-Haynes-manual_W0QQitemZ250083516630QQihZ015QQcategoryZ18439QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
keep an eye out - i got mine last week off ebay for ?7.99 with postage and it was still in the wrapper
was a bit hasty and bidded ont his before you reply. states its for small block engines thoug
http://cgi.ebay.co.uk/…em=190082006334&rd=1&rd=1
hope its the right one! :roll:
thanks again
then switch her on again…..
carb cleaner iv very flamable so if there are any air leaks it will suck in the cleaner fumes and put the engine revs will pick up for 10 to 20- seconds..
do be careful not to get any on exhaust bits tho as i did say is flamable - i would hate to see ya car go up in flames.
this method will show leaks for sure - there maybe better ways though but thats how i do it - unless its obvious
if once you change the points Etc you still get the problems then look towards the carb
logic said
Car Parts & Spares -- Buy Online with Fast UK Delivery | GSF Car Parts
is this similar to yours logic? is it bosch? thanks
there is a serial number on the distributor body - what is it…. i had a couple of serial numbers so i wrote them down and emailed them to gsf to see if they knew - they mailed me back a say later and said bosch…
your maybe the ducellier version…. i personally think its hard to tell.
but doesnt look the same as mine.
yours does look clean though and condenser looks newish….id try just looking at your contacts first and seeing if the gap is correct and that there isnt any damage to the points.
where are you from???
