Misfire and Lumpy Idle
I have checked under the bonnet at night, cant see any sparks but get this is no guarantee that they are OK.
Yeah I dont think that test is conclusive. I've never seen any!
I found a misfire on a Polo this way, actually the spark earthed into my finger so I would have probably noticed it in daytime too.
Peter.
1980 1600 GTI, daily driver.
New HT Leads arrived and have been fitted and the news is…….. Not good!
Misfire is still there, I'm thinking possible WUR now, can anyone tell me what symptoms I would have if this was playing up????
http://i169.photobucket.com/albums/u210/TheCampaigner/100_1444.jpg
If it helps, you could bring it over and I could take a look at it. There's lots of things I'd be tempted to check:
* Compression check on all 4 cylinders
* Ignition timing, including mech and vac advance achieved
* CO during warm up and once up to temperature
* Fuel pump delivery rate
* Good look at the microfilter (the tiny one inside the fuel line just before the pump)
* A good look into the fuel tank, to look for dirt in the system, or rusty inside tank
* Electrical continuity at AAV and WUR
* Operation of the 5th injector
I have checked all arounf the manifold and cant seem to find any leaks, will check again though tomorrow.
Paul the symptoms are:
Lump from cold, idling at about 500rpm until it starts to warm, the was a strong smell of fuel too but not noticed that recently.
They engine finally settles down to a slightly lumpy idle once warm (about 900 - 950 rpm), then once warm and the engine is under load and below 2000rpm it has a misfire, as soon as the revs build the misfire clears.
I cant decide if the car feels a bit slower too, but maybe that is my imagination. Also not getting great economy from it (about 27mpg on a run)…
Any ideas????
Where are you based Paul??? Cheers for the offer of looking over the car.
Might well pop over if I dont get things sorted this week.
When I last went to the garage the messed with my emissions and idle speed, they would them down to as low as they could get them but not convinced the car has run right since!
The electrics to the WUR look a bit dodgy although they are all intact, sorry to sound thick but whats the AAV????
1983 Lhasa Green GTI
The plug leads do seem to have made a difference, the misfire below 2000rpm has actully disappeared, however, the misfire when it is parked for 20mins so still warm??????
I'm really at the moment! Think i'm gonna have to take Paul C up on his offer of having a look.
I'm wondering if it could be the WUR, i've tested the AAv and all appears to be fine, not sure where to go next!!!
still points to leaking injectors to me mate.The Campaigner said
They were fine, thought it may have been running rough but all a nice tan colour!
Regards Volkswarren
I've just not got the money at the moment! Where is the cheapest place to get the?? I'm thinking GSF unless any of you guys n girls have a better idea!!!!
Regards Volkswarren
Thanks for the tip, a set of 4 injectors purchased this evening. Was gonna try the cheap option and buy 1 but not sure which one, if not more than 1, is causing the issue!!!
Fingers crossed now for a misfire free car!
Thansk Again, I'll update you as soon as I've got them fitted!!!
Thanks,
Duncan
It misfires and idles badly as above but still runs and revs fine and is ok through the gears.
If i take the injector out this weekend will an airline blast fix it or am i soon to be off to crazyquiff with my readies?!
Ive got the injector test downloaded but i think mines already been diagnosed as number 2 cylinder :?
I replaced all igintion parts today and noticed one plug was wet…I'm guessing the injector is leaking?
checked the spark plugs, starting from the crankshaft end working left to right:
1st is fine
2nd is physically damaged AND covered in OIL
3rd is in a similar condition to the 2nd but no oil
4th is fine
any ideas anyone? seals? fuel/air mixture?…it does tend to sup an excessive amount of oil.
plugs have been in the engine for around 8,000 miles and engine was reconditioned in january, which is still under warranty…do i have a case for presenting them with the solution…?
cheers for any help / advice!
