1.8gti thermostat problems
how long have you run it for once the temp gauge gets to normal?
where abouts could the blockage be, cos the pipes get red hot and so does the thermostat housing unit execpt that 1 pipe
if everything is hot except for the bottom hose, it sounds like there is no blockage, you just have to wait for the thermostat to open which as i said above you need to just let her run with the rad cap on till the fan comes on then top up once cooled down.
Regards Volkswarren
i let it get to 100 degrees and the thermostat till didnt open
Bert said
me think they open at 87 degrees?
Bert
ye that right
Regards Volkswarren
volkswarren said
where did you take the temp reading from?
off of the temp gauge i have, i have oil pressure, oil temp and water temp
Bert
Oh,if it squirts with good pressure when revved the pump is working
Regards Volkswarren
volkswarren said
hmm ok but if its pick up is nearer the manifold, or outlet off the head the water will be hotter there, i really think u need to run it for a good ten minutes, it is supprising how long it will take as the botom hose is cold the other side of the thermostate untill it opens.
the sensor is on the bit where the pipe from the top of the rad and the pipe coming out of the top of the water pump meet
Whereabouts are you located?
Plymouth
so its on the water outlet on the front of the head, which will be alot hotter than the thermostate, untill the system is all running correctly, and the thermostate has opened to allow the water to flow through the rad the water in the head is very hot, if u leave the cap off it will boil well before the thermostae opens, the system needs to be run with the cap on, keeping an eye on the gague on the dash, the thermostate will open and the fan come on before it moves all the way to the right of the gauge.
Regards Volkswarren
