Tuning a 1.6GTI Old Skool Style
Skeete Stuff, note the comment re the bank balance being kept more healthy doing it in this order:
CCC Tune-In article, ignore the Mk2 golf GTI, and the 2nd pic being a mk1 golf engine shot ?!?!?, engine logic no doubt is the same
however…
… cunning me kept all the bits! teehee :mrgreen:
should be picking up mk1 number 2 this week! WOOHOO!!
i'll get her rolling roaded once all the bits are bolted up and post the figures up here so you have some kind of reference, have to try and source another cam though, last one kinda didnt like the wrong pistons that were in there… compression was a tad high so i never got the damn thing running right before she left me :roll:
'69 MG Midget 1275 (currently restoring, cammed and ported head) '81 Lhasa 1600 GTi - kent GS25 (294) cam, full supersprint mani back, filter, 2.2 throttle body '82 Audi 80 Sport '97 20VT Passat (AEB with a 57i) '84 Silver Campaign - DX but AEB coming
me said
you need the golf october 03 issue theres a tuned 1600 by volkspeed in there.
spec in short
30 thou overbore
forged pistons
fully lightened and balanced
group A head with gs25 cam
audi 5 cylinder throttle body
4 branch manifold
All of which you should ignore, I should know, I built the REAL engine for that mk1… :roll:
chopperoli said
What do you mean? Is that spec not correct?
The more I think about it (it was some time ago) I think that was the engine in the car when the shoot was done, I know that engine was removed before the car was sold.
40/35 valves, Schrick 276, 10:1 comp 1mm overbore pistons. Whaddya think
It had a ported cast manifold which was a work of art, must have been a weeks work in it.
Most of the group H cars in Germany don't use the heron head (EG) but use the FM chambered head instead.
Keeping the short stroke is a good idea. If you deck the block 2mm you can use G60 pistons (81mm)
I thought a 276 Schrick would be a good compromise. That's also why I am keen to retain lower compression ratios, so I can keep using 95 RON.
I've got a feeling if I go much over 10:1 there will be issues with pinking with basic K-Jet.
Are you implying that the fuel metering head that car used was a custom/modified unit? Or just one from a different model but in disguise?
Interesting about the G60 pistons you mentioned, have you done this? Don't know anything about the G60 block, do those pistons use the same wrist-pins? And the C/R?
Cheers for your advice, sounds like you know what you're talking about although I must admit i don't see how what you said about volumetric efficiency applies to this?
Oli
I hope it wasn't! I bought it from Neil and apparently it still had it in! it did go very well!
addicted said
10:1 compression is very low to be honest, remember thats static compression and the longer the duration you use on the cam then the lower the volumetric efficiency is. The original engine had 41/35 valve, lightweight followers (using lash caps) Schrick 325, Mahle Intruder pistons (approx 13:1 compression). The injectors were from the M10 BMW engine and the fuel metering unit had NO part numbers!
What sort of power and torque would this spec motor make?
'82 Mk1 GTI 1600 UGY74X
(Mars Red, mostly…)
(Mars Red, mostly…)
Snoopys Eurotune Autosport on FBook.
http://www.facebook.com/Sn00pyB0ttz#!/pages/Snoopys-Eurotune-Autosport/160536723976091
Contact me for parts you need but cant find!
You would be better off asking technical questions on a different forum mate, this one is all questions and no solid answers.
mags
Seeking a copy of fast car magazine issue num 09. It feat a MK1 GOLF TESt. It has 2 Skeete cars a white mk1. And a Yellow mk1. With a helious mk1 Shoot out test… the FRont of rhe mag feat a split of 2 sierras POWER and STYLE…
Thanks in Advance..
