9" servo conversion question????
Regards Volkswarren
I'll try source one ( don't think the car will make it on Friday
Can the master cylinder stay the same, or do i need both the servo AND M/C?
Cheers, I owe you a pint!
J
Regards Volkswarren
perhaps before and after piccys?????
this is all i need to crack on with mine.
ta
John
1983 mk1 gti 2.0l 2e powered
newman cam
ported, polished, big valve 1.8 head
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
chudd said
Yep metric standard ……….
Cool, thanks mate
I have pics of two mk1 16v`s with this conversion and they both have only one electrical connection to the master cyl.
I have a 4 port 22mm master cyl and 9" servo from the mk2 16v. There are 5 connections to the original m/c, 3 hydraulic (one with a T in) and two electrical.
I am planning to use a single port for each front, a single port Tee`d for the rears and a single port Tee`d for the electrical connections. Or use a single port for each rear with a tee ineach for each electrical connection.
Would this be a satisfactory way of doing this? Or is there a simpler/ better way? :?
F#$k them New Model Cars We Ridin Old School
I had a 2 port 16V master cylinder, so I needed to use T pieces anyway. So I used the original T piece and 2 more to achieve 5 connections, one for each wheel and one for the brake light:
It is important to make the connections right, so that the front of the new master cylinder feeds the front right and rear left wheel; and the other one feeds the front left and rear right wheel. This preserves the safety benefit of having dual-circuit brakes.
Couldn't be bothered with this so I took the pedal switch off a my 94 passat, and fitted to some angle steel and bolted it to the pedal assembly.
They have a captive nut in just the right place, think it's for cedal switch assembly for scirocco, or someone told me ages ago a very early form of cruise control??? Or maybe the were taking piss out of me?
teammonkey
g1 said
Cool I have one of those for parts tooo…………. a 94 passat. Or would it be just as easy to eliminate one of the brakelight switches, using only one and just Tee it into one of the lines?
That's what I did. You need to fit at least one more T piece anyway, why not just fit another while you're redoing all the plumbing?
