2 litre powered!!!! ( lots of piccys)
Any updates for the post?
Anyway, I think i've got all angles covered - apart from the cam belt cover (top and bottom parts). Did you use the orig one from the 1800?
I've got a supersprint 4 into 1 manifold, which is one piece and therefore can't be 'dropped' by use of a sandwich plate - slightly concerned about clearance…..
Current Toy: Mk1 Golf GTI Cabrio Sportline (Red) 2 litre tall block , high lift cam, Audi WUR & throttle body, 16V fuel metering head, Supersprint 4 into 1 manifold, adjustable coilovers.
You'll need:
037 109 107B - Top cover
048 109 175A - Bottom cover
048 109 173D - Top bracket attached to the cam cover
048 109 129 - Back plate sitting behind the pullys
The top and bottom covers will need a little modification to fit around the Mk1 engine mounting.
The top cover is squarer compared to the rounded mk1 original.
peeriehutchie said
am building a 2 litre agg code for mine , and the dizzy needs an adapter sleeve , did yours ?
Luckily my donor engine had already been installed in a Mk1, so all major mods done
