Cabrio hood replacement
(In Topic #78479)
I'm about to go outside and start to rip my old roof off!!! :twisted:
What wheels are on that black cabby in the pic.
Adam
Here are some pice of my work so far.
Before! Hood was bowing due to no side cables and also cracking up in a fair few places.
After!
There ain't much rear window frame left!
There's lots of cleaning up to do of the frame and rust on the rear lip before I can fit the new one. I've got alot of other pics to hopefully do a "how to" but some didnt come out as well as I'd hoped.
DubPartz
Here's a pic of the front end. You can see there was water trapped under the outer layer! Maybe this hood was porus like Prowler said his was :dontknow:
And the rear window frame….the outer skin is stapled to it but what do the staples actually press into….is the a wooden frame, 'framing' the metal, like the Cabrio Beetles have ?
DubPartz
The plastic insert is fairly soft, easily stapled with a power stapler…
The rear frame is part metal, part something else! I dont think its wood as I mine would have probably rotted away. I think its a plastic but I'll investigate further sometime.
I won't be working on it today as I have the GF round but I'll be working on it during the evenings this week weather permitting.
mine was rusty in the same spot down by the bracket. but not as bad i was dreading opening it up tbh. the roof frame looks pretty good tho.
best of luck fitting it, i wouldnt have done mine without another pair of hands there to help it was alot easier that way.
rebuild in progress....
I've tried out the stapler I have on the old frame and it seems to work ok, might need to help them in all the way though.
The frame is sooo rusty, its all the way along the bottom and up the sides a bit too. Its definately not wood, but plastic like it says in prowlers diagram.
I've still got the rear side flaps to glue, refit the rear side seals, fit the rear window and trim the excess hood material away. Not far to go though. Its been pretty easy to do really… so far! Could still come across a problem yet so I'm not counting chickens!
Here's a pic of the header, you can see one of the clips where one of the screws for the side seal bracket goes. I think these are often fitted under the hood fabric by trimmers. I think they would have been above it originally like this…
I've fitted new genuine VW gaskets to the side seal brackets, before there was only silicone there, a possible cause for leaks by the roof handles perhaps?
I'll try and do a decient 'how to' after its complete and add links to suppliers of hoods etc. One for the knowledge base hopefully. I'm not sure how I'm going to host all the pics though, there are quite a few. 8)
Finally finished :cheer:
Now to write up a how to guide and get this car MOTed and sold :cry: I'm quite torn between this car and the sportline.
I especially like the shot with the knife? on the roof, prior to making the incision !
DubPartz
Have you decided which one you are keeping?
Will you be bringing it to the south west meet ,I will try to make the next meet to check it out.
Mark
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
I've decided to keep the Sportline as I've got pretty attached to it now! Its still a bit scruffy but will look ok in the end.
I need to MOT the '88 soon, so if I get it sorted soon enough, I'll bring it to the meet for sure. It's got a full tank of gas that needs using before I sell. :wink:
Hows your project going?
what kind of glue etc you used?
i'm goin to have a go at mine and want to make sure i'm prepared before i start
TG
Need your console repaired or mods done? drop me a pm
