cv joint help needed *******update********
Early-1800 said
The bolts are U/S and you need new ones so hammer in a larger bit to remove them.
I agree with that, if you've rounded a allen/torx or spline drive bolt goto the next size up and hammer it in - you can worry about getting it out later in the comfort of your shed etc in a vice. Then if it still rounds goto get the dremmel or grinder with a cutting disc and cut the thing off :evil:
I find that caliper bolts with the allen key heads always do this too
wish i could remember the name ops: I know they are made by Stanley though……
I brought out the secret weapon! All those easily offended close your eyes now or prepare to wince….
Take that evil bolt KAPOW! :twisted:
I never though in a million years it would work…. but it did!
Lukic said
Dunno if you've managed to get them off yet. If you havent, there is a set of tools, cant remember what they are called but they have a pointy end and left hand thread and you screw them into the aperture you've left when you rounded out the star hole. As they get further in they 'bite' into the remasinder of the bolt and turn it undoing it. I got a set of these in various sizes about 3 or 4 years ago for exactly the same job, worked a treat and cost about 15 quid! I bought them from a local hardware shop.
Are they stud extractors? :dontknow:
I know the tool you mean, the problem is that bolts are typically made out of a harder than average type of steel and the tool will destroy itself before it does its useful job (or maybe I've just bought rubbish tools??)
Trust me, the 'grind a slot into the head of the bolt' technique is the quickest one, from bitter experience…
File 2 opposed flats onto the bolt head. This allows you to bodge a spanner on it.
Get a cheap socket set from somewhere like Wilkinsons…..find a sockets that only just fit over the bolt then bray it with the "T'hammer of doom"! Chase this up with an impact driver.
Failing that use the "Mole grips of destiny".
There is more than one way to skin a cat! :wink:
Oh use Plus Gas too that stuff is magic! 8)
My final choice was one of these;
made light work of the bolts :twisted: :twisted: :twisted: :twisted:
couple more questions now tho.
I've got all the bolts out the inner side and i've took the bolt and the washer out of outer end but it doesnt budge? if there any other bolts i need to take off? i've got my replacement shaft to go on but cant get the old 1 off!!!!
also lost alot of oil taking the inner cv apart, is that from the gearbox?
1272 driver with a magic tree!!
There should be no oil getting out of the box. There are oil seals around the drive flange from the g/box and one in the centre that you can see when you get the shaft off. You might get the odd drip but not lots. Are you sure its oil and not grease from they CV joint???
I think now you will have to undo the lower ball joint and swing out the suspension strut to create enough room to remove the shaft.
and yes it deffinatly is oil, and i lost alot of it! :evil: :evil:
it was smaller diameter than the old one but it seems to fit ok?
i think now i need to top up the gearbox oil, it has lost oil from the gearbox as you can put it into any gear without even pressing the clutch in??? it this big problems? im hoping i can top it up and this will cure thatproblem if i do top it up will it start to leak? im thinking this has what cauzed my problems in the first place as i remember there being a bit of oil around the inner cv when i broke down…….im really hoping i can start driving again soon!!!!
please help!!!
I'm worried for a couple of reasons-lowmk1 said
right chaps, i've managed to get the new drive shaft on!!!!!!! :mrgreen:
please help!!!
if there is oil leaking for the 'box you need to stop it by fitting a new seal(s) on it
and the other is the shaft diameter, you say it was smaller???? it doesn't seem right to me, does it lock onto the diff and hub ok?
and theres no way you should get any gears without using the clutch :?
Im also worried for you about loss of oil… did you take the flange off the gearbox?
And you can put it in gear with no clutch… interesting. Is the box noisey? :dontknow:
cant belive this, just when i thought i had dne it….more problems!!!!!
so i'll add an extra ?30 to my list as i've bought a wrong driveshaft and how can you tell if its a mk2 box?
kins what part it the flange???
everything was fine when it was runing no noise or anything
feel like smashing it up
The CV joint might suffer slightly (grease being contaminated with gearbox oil), but you can clean it out and repack it with grease, when you eventually swap the box or sort the seals on your existing one.
Swapping the gearbox is approx 3x the length of time as swapping a driveshaft, if that gives you any idea of the duration/complexity of the job. An engine crane is handy too, to support the engine while the box comes off.
i found out that you can top it up by eithor the 17mm allen bolt(but looks like its rounded so not gonna try or speedo cable? but not to make sure it drops off inside…
most likly will tyr the speedo cable route…need a good 'how to' on how not to break the gearbox by topping up in the wrong place answer first tho :mrgreen: :roll:
well if it takes me 2+ months to swap a driveshaft….errrr i'll give it a miss!
big grins my way!!!! :mrgreen: :mrgreen: :mrgreen: :mrgreen:
yea kins your right mate, booted it and it torque steers very badly! hard to keep it in a straight line, oh well dont need the gym anymore
