low power arc welder , anybody used one ?
The wire feed is a bit cack on the SIP 105, I've found it doesn't grip the wire very well, the rollers don't meet squarely because the plastic holding the rollers flexes. I've modified/bodged mine a bit so its better. I have seen other cheap migs with more problems with the feed though.
Mines a few years old so maybe it been improved :dontknow:
As for the tube to the handset… I havent really had any problems, you just need to keep it as straight as you can and don't lie on it too much! I expect other cheap models are the same.
I'll get a pic of the bodge if you like
If I'm honest I still haven't summoned up the courage to get the Mk1 hoisted aloft in the garage and start the LONG list of things that need doing to get it shipshape again:
- brake lines and the flexi hoses
- fuel lines
- blowing exhaust manifold
- fix leaking cooling system
- cylinder head swap
I just have this feeling that once I start dismantling things I won't know where to stop!!!!
Anyway, back on topic, as I figure some welding may be on the cards when I start dismatling things :wink: .
Anyone used / heard anything about the slightly more expensive Butters or Sureweld units? Granted they are a bit more expensive than the equivalent Clarke / SIP, but I'd hate to buy something that gives me grief and then end up wishing I'd spent just a little bit more to get a quality item……
http://www.buttersamt.com/
Anyone got any good sources for online suppliers of other MIG manufacturers aside from Clarke and SIP?
From what I have read a lot seems to come down to the quality and consistency of the wire feed mechanism……
Chris
Just need to shop around, but seems pretty reasonable to me.
The Cosmo range of MIGs are re-badged SIP units but cheaper - I don't know if all components are same or cheaper tho? Looks the same.
paul_c said
I bought some consumables from a B&Q superstore recently. A bottle of Argon/CO2 gas was ?7.98 from them, compared to ?13.50 from another shop and ?10 + VAT + delivery from www.toolsbypost.com, so I think that's a decent price!
Just as a bit of feedback, this bottle produced crappy welds compared to the CO2 I got with the machine; and it ran out in an incredibly quick time. So I think I got a dud. The shop is too far away to make a fuss of going back, etc and they'd never refund my travel costs or the time spent having to grind out dodgy welds, etc.
So I went to a proper gas place - just my luck, their computer was down, and these days you need a computer to give you gas. This might be of interest, though:
http://www.bocindustrial.co.uk/
Its ?45.30/year for the gas bottle and ?27.14 for 2 m3/3.4kg of the gas (Argoshield Light), which comes in a 19kg bottle which is around 1m tall. For comparison, thats ?4.81 per 600g, compare that with the little disposable bottles.
Do you get the regulator from them too? :dontknow:
Hairyarse said
Cheers for the info Paul :wink:
You can buy the regulator from BOC, but when I picked up the gas today they didn't have all the bits. So, I went elsewhere for the regulator. You also need some other adapters:
Regulator ?40
AK9 Gas adapter kit (the tube) ?8
3/8" BSP R/Hand nut ?1.28
3/8-3/18 Hose nipple ?1.28
All plus VAT. So I'm a bit over budget after all this! Basically, if you mention you are connecting it up to a MIG welder, they should sort you out. The guy at BOS who I dealt with was very helpful, so I can give them a big thumbs up!
