MK1 GL Auto
MK1 GL Auto
Manufacturers do much work to design their braking systems so that the front/rear bias is correct. Since this varies with load, thats why there is a compensating valve which is based on suspension displacement.
…but only on SOME Mk1 Golf - which is what this website is for afterall.
Have you ever been out in one that's been lowered and the rear bias valve hasn't been adjusted? *spin spin spin crunch!*
I don't understand, VW designed all Mk1 Golfs, right?
Wrong - Ital Design designed the Mk1 Golf.
Only some Mk1's are fitted with a rear brake bias valve - what's not to understand?
I got you now! Feel free to call me bird brain of Britain, if you like!
Life Member
Not 100% correct. Much of Giugiaro's original design was changed by VW's Herbert Schaefer for production. For example, the headlamps were changed from rectangular to round and the bonnet lengthened.
If we get into specifics, then Ital Design only really designed the basic shape, styling elements (some which were changed) and probably (not sure) dashboard and seats. VW developed the floorpan, inc suspension, brakes, electrics, etc. I know the big block engines were originally an Audi design, I'm not too sure about the small block…..
What does any of this have to do with rear brake efficiency anyway?
So what you are saying is that Ital Design DESIGNED the car and VW's production team translated that original design into a viable product for economic mass production? All VW's modifications were to the original design of the car - ie. they didn't throw the Ital Design masterpiece in the bin and start again then?!?
Life Member
Got the new bumpers fitted, although they need a bit of persueding still cuz in places the fit isnt too good. Also need to put the chrome strip down them as theyre all black.
Also fitted a new alternator and this has cured the starting problems.
She went off this morning for her second MOT, good as gold, no dramas so Im hoping she will pass!
1983 MK1 Tintop
1968 Karmann Ghia
1994 Passat VR6
1996 Passat Diesel
1968 Karmann Ghia
1994 Passat VR6
1996 Passat Diesel
1983 MK1 Tintop
1968 Karmann Ghia
1994 Passat VR6
1996 Passat Diesel
1968 Karmann Ghia
1994 Passat VR6
1996 Passat Diesel
dubgrrl said
WOOOOHOOOOOO SHE PASSED!!!
What was the fix for the brakes then? LOL
Well….
New rear drums have sorted it.
No mention in this mot of this compensating valve thingy so all good!!
1983 MK1 Tintop
1968 Karmann Ghia
1994 Passat VR6
1996 Passat Diesel
1968 Karmann Ghia
1994 Passat VR6
1996 Passat Diesel
dubgrrl said
Haha! You want to know?
Well….
Good news!
Its always been a bit of a dilemma. If your car fails its MoT on brakes, and the fix is to replace pads/shoes/discs/drums, then of course the new ones sometimes need bedding in, before up to full efficiency. Problem is, this takes 100 miles or so to do properly. So, you can find yourself in a 'catch-22' situation! The only real solution is to let the garage do it, they'd replace the parts and some of them wouldn't even bother to put it onto the rolling road again. Others would accept a low efficiency brake system, knowing its going to get better. And others would 'bed them in' on the rolling road. Hmmmmm………food for thought, if your brakes are bad and you have an MoT coming up……..
Yesterday I replaced the whole lot for piece of mind on both sides… drums, wheel bearings, shoes, cylinders and fitting kit.
I've taken it for a spin down the lanes and it seems ok. The handbrake's loads better. I should have checked it all out before putting it through. Lesson learned!
I'd had a look through the back plate inspection hole and the lining looked dry with plenty of lining left. When I removed the drum I found the cylinder had only weeped slightly but enough to get on the linings. The drum's surface had become oval and it had worn to the max diameter (think it was the original drum). The drum the otherside had been replaced at some point but you're supposed to replace them in pairs so I did.
If it fails again I'll be even more :evil: and… get stung another ?44
Fantastic stuff!!
(I'll have an MOT'd Mk1 by Friday too - hurrah - the summer is a comin' (after the ice finishes taughting me!))
