I went n bought it!
(In Topic #75744)
I went n bought it!
http://cgi.ebay.co.uk/…Z9873QQrdZ1QQcmdZViewItem
Oh **** thats my 3rd golf!
I went to see it after the south west meet still golfed up to the max!
No one was there to let me have a look it properly so I havent even heard it running! but from the outside it looks ok although it looks like its seen a bit of front end action as its had a new wing. The front panel looks straight and original though.
It doesn't look like theres any rust which is nice!
For that price you really cant complain much can you :mrgreen:
any comments!
Cheers,
Ross (still buzzing!)
MK1 GTI Campaign
MK2 GTI 8v
Imitation Magic Tree - 'Black Ice' smell
Plenty of rust
Embarrasing fuel problem
Porous cooling system!
MK2 GTI 8v
Plenty of rust
I've now filled up my parents garage so I'm going to start using my brothers drive now!
I will get rid of one, probably two in the end but don't know which or when yet. A lot will depend on how good or bad this sportline is.
It is a bit tatty, has small dents here and there. The rear tyres are good but the fronts are on the wear limits and one has lost a far bit of air as you can see in the pic (they're toyo proxies).
Some of the bodykit isnt original to the car as you can see a metalic green paint showing through in places.
The first MOT fail I can see is a split CV boot. It might get away with the hole in one of the inner spots.
Looks nice m8 give you summet to do in these cold dark days good luck.
Unfortunately, I don't have the facilities, money, time, or space for another Golf, but apart from that I'd get a convertible!
I've called the seller and he seems to be pretty sound. I'm hoping to pick it up this week or at the weekend so I'll get some pics up when I do.
Anyone know what the deal is with towing a car without MOT? can you do it with a rope or does it have to be on a trailer?
MK1 GTI Campaign
MK2 GTI 8v
Plenty of rust
MK2 GTI 8v
Plenty of rust
Ross said
Cheers guys
Not sure about MoT, but if its untaxed it needs to be raised from the ground (ie its wheels can't be on the road). SO, you can't legally tow an untaxed car unless its on a trailer.
Or, maybe I could book it in for an MOT and say I'm driving it to the test or to my local to home garage for repair?
Aparrently it drives ok.
Why not do what I did? Pick it up in the dark, and break down hundreds of miles from home, so it has to go on the back of an AA truck?
What was the AA guy's reaction when you did what you did? It is tempting as I have personal breakdown cover.
Ross said
Are you sure it needs tax to be able to take it to a prebooked MOT?
You might be right on the tax situation - no tax needed for taking to a pre-booked test.
The breakdown was a genuine fault, it was a ?500 car so I was expecting something non-perfect about the drive home, but I wasn't expecting a breakdown, then the AA guy to spend an hour trying to fix it but not getting it going.
It was recovered by an independent recovery firm, they have a section on the form to check for tax, but since it was dark and cold, the guy didn't check.
So, I'd rather have not broken down, but with being in the AA and suchlike, it wasn't the nightmare it could have been, and it saved a bit of fuel and mileage on the car.
Mark
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
But… Its a bit dirty 8O
Backbox has to go its way to loud.
The steering wheels….
Ahhh nooo! possible engine mods! don't know whats been done. Has anyone heard of these tuners?
There's no VIN plate for some reason but chassis stamp and boot sticker are intact. I think the front panel might be original as it has original stickers.
The top mounts look and feel a bit warn….
Whats the grease about?!!
Gear selection is really difficult for 1st and 2nd. The chap said it had a 1.6 gearbox fitted when he bought it and then got the correct one fitted on the cheap. I think its actually a good box, it just needs mounting properly. Don't know how they managed this…
Hmm…
The MFA doesn't work. I think its possibly because the wrong switch is fitted rather than the dash been converted to just having a clock. The wipers did work but then the fuse blew. The push button is supposed to control the washers!
This is the only real problem with the interior apart from the front tweeters being butchered…
The active sub's a bonus…
But will probably get rid of it.
There are other problems than need sorting for the MOT.
Brakes - the fluids on minimum so somethings up.
Split CV boot
I noticed the Aux Air Valve is disconnected, That probably explains why the idle has been set a bit high.
Also the power hoods fluid is on minimum and the Cobra alarm doesn't work, the imob does though.
So what do you think!!!!!!
Cheers Chudd, I cant wait to get stuck in. But then I should really get on with the other project first!
I don't think you could actually make out who the engine tuners were in the pics so here are the details. It would be nive to know if they still exist and even better if they could tell me whats been done. I havent tried calling :roll:
Martin Smith Motorsports 01733 253326
