Hi all
(In Topic #74858)
Hi all
I usded to have a mk2 gti now breaking ops: but means im getting a mk1 :wink: :clap:
Seen one, VW Golf 1.5 GL MK1, 1983/Y black 5 door 95000 miles MOT till Oct road tax till end of Dec 05. Good runner, v.good condition in and out with CD player, original docs and service/car history.
Got extras with it. Original hub caps, haynes manual for the golf & spare
near side wing & original owner docs and golf broucher.
what do you think she is worth?
Tucker
Tucker
Could I use my mk2 for parts?
Tucker
Life Member
Tucker said
thanks for the welcome. just hope the sale gose through.
Tucker
Depends which parts and which MK2 you got. I doubt many though - dubboy will tell you tho :wink:
cant wait :twisted:
One or two probs with it, hard clutch. chap said that it has always been like that, high too. :dontknow:
Buzin inside the car. he says that the buzz that comes on is the oil pressure switch. For some reason there are about 6 oil pessure switches for MK1 golfs, so my machanic thinks that I've got the wrong one in hence the buzzing. :dontknow: I just
hit the dash board and it stops it not the best solution!!!
good to haggle with :wink:
My mk2 is an early 84 gti kjet. sold the engine and box tho, been lowered. Could I used the brakes or anything?
How much should I be asking off the asking price?
Tucker
Life Member
If bashing on the dash stops the buzzer it sounds like a faulty circuit board on the clocks. Although it is unlikely to be the oil pump, knock the money off for a new one as worst case and check you have decent pressure.
You can fit the brakes from the Mk2, but the only thing worth uprating is the vented discs. As they are cheap anyway from GSF, why fit used ones? If you upgrade, make sure you get the thinner GTi pads too.
I would ask for ?100 off, but I would not buy it without the MOT first.
Rajan
No point with the mk2 then, she can go to the place in the sky
The guy is looking for a new car fist so have to wait :boohoo:
tucker
would be good to see your new purchase there
Will not be able to make the meet. Got to much on.
Only driven it home tonight and to the garage and shes great
Put on some wheels today, think they are the gti ones, 13s. will take some pics tomorrow, cant wait to give her a polish, not that she needs it as shes like a mirror will have to wait for that tho :roll:
Clutch pedel is too high, right at the top. is it easy to adjust?
Tucker
Be sure that the bolts that came with the steel wheels are long enough to safely hold on the alloys, as alloys are thicker, and the bolts need to be a bit longer.
How to tell:
The short, steel-only bolts have a smooth top on the hex-head, with only the part no.
The longer, for-alloys bolts have raised castellations (like battlements on a castle) around the edge of the hex-head.
If you need the longer ones, any breaker will have them on a Mk2 Golf or Polo.
PS: If you ever put a steel rim back on the rear drums (spare wheel?), don't use the long bolts, as they can foul (and destroy) the brake-shoe assembly!
Ah well try and make it for next month if you can!
What ya think?
tucker
Life Member
agreed value cover. :dontknow: Im using adian flux (was on my old golf and transfered it over. cost more old one was a mk2 8v gti :dontknow:
what you think she is worth and what you think i paid??
Oh… the mark on the bottom pick on the wing is not on the car, bloody phone :roll:
Tucker
