Cold Start Problem (again)
(In Topic #73998)
Will only cold start after cranking for about 10 secs with foot on the floor. Once started sounds like it's running rough/missing for about another 10 seconds then all of a sudden that clears and it runs fine.
Cold start injector is working and thermo time switch ok - i.e. getting 8 secs of additional fuel from the CSI when cold starting.
Could be an air leak but I don't really think so.
Done a full fuel system pressure test and all within spec - injector spray test is OK also. Timing is on the button.
Anyone got any ideas on this?
One thought is that the CSI is firing too much petrol (worn injector) making a very rich cold start mix????
Problem is the same with the CSI disconnected.
Will start with a compression test and a good look round for air leaks. Then maybe swap the CSI and TTL for known good ones.
Also used some injector cleaner - wynns i think - improved performance on both the black Campaign and the cab.
Do a leak down test with the injectors out. sound like they r leaking
Cheers Wellsy
1983 MK1 Golf GTI (Campaign?)
1983 MK1 Golf GTI (Gone to VW Heaven)
1990 MK2 Golf GTI G60 Edition One
just thought that if there's more fuel getting in, it would still start without throttle… and probably wouldn't with full throttle
dunno, maybe the sensor plate is sticking open a little or has too big a gap round it?
as you know i'm still trying to understand the forever seemingly annoying fuel system and setup but thought I'd add my 0.5p worth :wink:
My Build Thread
Rich have you ? Leads , cap , rotor arm , coil etc etc ….
Nigel C….
The Astra i ran this winter was a pig to start from cold when warm no problems . I looked [that is just looked] at the ignition system and decided it was that crappy auto choke system that Vauxhall love playing up , so i bobbed down to the local scrappy and spent a tenner on a replacement carb with all the bits on . You guessed it same next morning so i checked the ignition , the ends of leads feel apart in my hands , the dizzy cap was burnt to a crisp inside the rotor arm black , replaced cheaply never had another problem .
Had the last laugh with the Astra though - Scrapped it last week -
Gonna check everything out before i splash the cash so will look at fuelling first methinks and make sure that is on the money. Worth doing anyway i rekon
I'll keep this post updated - thanks for the ideas :y:
1983 1100 C
1983 1100 C
For the money a new coil, decent HT leads and a dizzy cap and rotor arm are probably money well spent for piece of mind.
I take it you have had a chance to try out that fuel pressure test gauge from JC Whitney then? Was it any good? Mine is still in its box at the mo since the fuel probs were been fixed using Wellsy's gauge….
Chris
fitted a pressure guage to injector line 1
Ran engine up to temp
40psi on injector at idle
switch off engine
Pull all injectors and place in bottles
Walk away……………
Came back 24hs later
Pressure guage reads zero 8O
Can't see fuel in jars one to 3 but jar 4 has about 1/4 a teaspoon in it
I think conclusive proof that I've got leaky injectors
Might just have to buy new - anyone got new recently and where from?
That place in the states looked quite cheap imo.
Rich
Think the Acumalator only supposed to maintain pressure for a couple of hours. Would have thought any system will lose pressure after 24 hours.
Peter.
1980 1600 GTI, daily driver.
tallpete said
24hrs?!
Peter.
A properly-working accumulator keeps the pressure for weeks - I've started my Golf after about a month, and it still started within about 2 seconds. However, when the pressure is fully lost (eg: fuel filter just changed), it takes up to about 10 seconds to build up enough pressure to start.
even the control pressure from the warm up reg is on the same feed, they all come off the distributer.
Theres no one way valve in the distributer, it's always open to some extent dependant on control pressure.
Type 17, I have always read the accumalator was only connected with poor warm starting.
i.e when the cars cold the warm up reg, cold start valve and aux air valve all do their bit and the lack of pressure doesn't matter so much.
Peter.
The fuel ditributor acts like four valves closing off the pipes to each injector.
The accumulator is only there to deal with transient pressure losses from the pump - air in fuel etc and provides a short pressure backup.
http://www.auto-solve.com/mech_inj.htm
(If you don't own one/aren't interested, it's a good cure for insomnia )
If you want more details on individual FAQ's, this might be good.
How does the system keep its pressure from the accumulator forward and at what pressure? Eg its not working pressure so what should it be ?
I no an injector requires 3.3 bar to open and as soon as its open will close due to lack of pressure until it builds up again but if i go to my car and it hasn't been run for say a week there is fuel in the lines but its not under pressure just sat in the lines . Yet mine starts okay all ways first turn of the key .
Can injectors be chemically cleaned to give them new life ? Has any one had this done and if so how much was it ?
Cheers ……..
chudd said
if the pressure is dropping where is it going ?
Cheers ……..
The pressure can only drop after the engine is stopped if the accumulator, injectors, or system pressure regulator in the metering head are leaking (or some other joint somewhere is leaking)
When not at working pressure, the system should not have dropped below 23psi after 20 mins (Haynes)
Injectors can be cleaned, to improve spray pattern/get rid of leakage, but the spray pattern/leakage is more likely to be due to wear, in which case cleaning is no good, and replacement is necessary.
Cleaning (by ultrasound, incidentally) is most beneficial on diesel injectors, which get clogged more easily, and where the spray pattern is more crucial to good running. Smokey diesels are often due to clogged injectors, giving a poor spray pattern, and fuel not mixed properly with air is only partly burnt, leading to soot (black smoke).
