Shell now sprayed
Shell now sprayed
Wouldn't have said 1200 is to harsh to start with. I usually start with that or some times 800 on areas that need a bit of work and finish with 2400. G3 is great stuff, this will put a nice shine in after the flatting back. I rub it in with a cloth and polish it with a handheld auto-polisher. My polisher is a bit cheap - looks like a floor buffer. The best ones are the mop type ones which look a bit like an angle grinder, but much lower geared to avoid burning paint. Often best with cellulose to leave it 10 or so days after spraying before flatting so that the paint has hardened up nicely.
Keep on at it, you'll be grinning from ear to ear when you have nice shiney black Golf at little cost.
1983 1100 C
1983 1100 C
ChrisB said
That paint job looks not too bad at all, especially given you had to do it outside.
Just out of interest what sort of gun and compressor did you use? I have a small 1.5hp compressor and one of the budget Clarke guns that came with it and just curious to know if its possible to get a decent finish with this setup or whether I would be wasting my time…..
Chris
I'm using a 3Hp 24 Litre compressor and a Sealey deluxe spray gun (really nice and easy to use)… would have thought with your setup you'd be able to get a good finish..
markwon said
Phill, looking good, looks like you've got a nice amount of paint on there. How much did you thin the paint and did you thin more with each coat? I would have said 7-8 coats (starting with 50% thinners and finishing with 75% thinners) is best as you have a bit more depth to allow cutting back without leaving to thinner finish. Can be a bit if a pain, but really makes life easier when finishing off - I put 10 coats on when I sprayed a new hatch .
Thanks markwon, I put 2 coats of 50/50 mix, then 2 coats a little thinner (at a guess around 40/60).. kind of went on the thickness instead of preperly measuring it
probably best if I leave cutting back for a week or so and get on with the rear hatch and wings (next on my hit list I think), might even go for a couple more 25/75 coats if the weathers good this weekend .. plus I need to pick up more paint.. it's suprising how much you get through.
Thanks for all the comments guys and I'll keep the updates coming
REALLY can't wait to get it on the road now for summer.. First time driving a mk1 and I'll be like when I do
Oh, and as for little cost, worked out I've spent in total so far ?1600
worth every penny though if you ask me!
got the side windows back in (makes the car look SO much better!)
Not sure on the lighting, will probably use the standard lights!
Looks better in the photo's.. when you get close up there's a few uneven spots in the prep work :cry: but I'll tackle them once it's on the road!
not bad considering I've never welded or sprayed before (first attempt and all that)
In fact, here's the link to my photobucket… read-only password is :- golf
http://photobucket.com/albums/y12/PhillT1/
if any of you want to take a look
I want smoked clusters for mine. What can I say you're a man with good taste.
Hope our projects don?t look completely the same!
Are you keeping the wheels standard?
I'm putting Ronal turbos on. :wink:
going to keep the stock alloy's for shows and meets though as although they're very dated they do go well with the car!
Thanks for the comments guys
Ref the lights - the originals look better IMO - sell the smoked ones to kins! :wink:
Keep the photos coming you are giving me the inspiration to tackle more and more of my bodywork :y: . Get rid of the smoked lights, originals look better - particularly on a black car
1983 1100 C
1983 1100 C
We do think a like. I was going to go put BBS RMs on mine. Just sold them though as I though it was going to be too pricey for my project. :cry: By the time I put Schmidt rims and chrome bolts I thought the wheels would be worth nearly as much as the car. ops:
The ronals complement the MK1 and the biggest factor that swayed me was they are easy to clean ha ha
markwon -
The rear quarter windows are seriously easy to take out and put back in, just make sure your headlining is properly glued in before you put the window back in.. took me about 5 minutes per window, but 20 minutes each to glue the headlining!
that's just scarey kins If I decide to sell the rear lights I'll PM you first, might play around putting each of them on for a couple of weeks once it's on the road..
Agree with you about the cleaning, I hate cleaning my 12 spoke alloys on my *ford* ops:
1983 1100 C
1983 1100 C
