More starting / running problems - possibly fuel related?
Cheers,
Chris
1983 1100 C
1983 1100 C
See Crazyquiff's post on this subject for more details. Bottom line is I think its leaking, causing the mixture to be way too rich when the engine starts warming up and causing it to stall and then not restart.
I suspect the valve itself rather than the thermo timer switch that activates it, as the behavior is exactly the same with the thermo timer switch disconnected.
Next test will be removing the cold start valve from the inlet manifold to see if it is allowing fuel through after its initial 3-10 sec period of operation. If it is then the replacement is still pricey (50 quid + VAT from ECP), but at least I will know I have solved the problem.
If the valve checks out OK then I guess I'm back to square 1 :roll: , but the symptoms seem consistent with too much fuel, so its as good a bet as any.
Chris
Check the reply I put on Crazy's post.
As to the part no. for your fuel distribution head check your Bosch no. on your item. I think it will be the same as the Audi 80 item.
Simon
'83 Mars Red GTI
Loading...
This should help keep thing in one place and prevent duplicate info.
Cheers,
Chris
