Replacement engine
Replacement engine
Guest user
Guest user
lhasa said
Cheers Chris,
I'm a little more cautious with engineering company's after the recent complete restoration rebuild of my DX head by Princess Engineering, as you know the engine is running (just) on two cylinders after a recent rebuild.
Have you not got any come-back on these guys then?
Been down that road before, cash transaction trust and all that, never again. I've also had previous court cases with a poor resprays on a 2.8i capri and my Datsun 240z, which both went against me!
I was close to setting fire to the Garage. R&B motors of Westbourne in Bournemouth, and before you ask I've travelled about.
Worth sticking to the best.
http://www.prestigeengine.co.uk/engines.html?source=aw-engines
http://www.ivorsearle.co.uk/local.html
TSR-Performance Ltd
http://www.creweengines.co.uk/car_engines.asp
I know it was a while back but still it was very good.
Nick…
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
I've put my car into the local garage and told them to get the engine going as a temp measure. Next stop will be the VEG engine.
The garage called me to come and have a look at my engine, to my surprise the pistons were perfect, the valves, stems, springs were all perfect..what an honest garage.. He told me that part of the head gasket was blown because the head bolts were loose!!!!!!!!!!!! also the timing was by one tooth!!
The head is off yet again to be skimmed and will be on the car tomorrow and he assured me the engine will sound good. I have to pick up an ordered 3 way rubber hose that goes into the rocker cover from VW, only 3 left at VW!!!!
Chris
I had a good look engine with the head off seems remarkable that there is hardly any wear at all considering the hell that engine has gone through. Guess if she can travel a long way on only two cylinders must mean it is a very good engine.
1983 1100 C
1983 1100 C
All the garages are same, rush, rush and rush and forget to put everything back!
