Help!!!!!!!!!firing on 2 cylinders
Where did you get the work done?
http://www.volkspares.co.uk
Volkspare must have some satisfied customers, after all they work to a kite mark, sure some engine must fail but surely volkspare must sell thousands of units.
What do you think?
Personally, I've not heard a good report on one of their engines but then again it's usually only bad news that travels. That said, unless you have an equal number of good reports I'd forget them
Do a search yourself and decide on whether thats the route you want to go down.
I would have thought if you were willing to do a lot of the disassembly and re-assembly yourself that you could recondition an engine with a lot of quality spares for ?500. Maybe just have a machine shop check some tolerances for you, crack test the head and maybe push in some new valve seat inserts. Most of the rest of the process is really just cleaning, checking tolerances and renewing components where necessary isn't it?
This is time consuming, but I guess thats why prices are high if you get someone else to do the work - time is money!
The other big plus is that if you do the work yourself think how much more confident you will be about sorting out any future problems with the engine. Your understanding of that side of things will be greatly improved imho.
I think the things you would be wise to have replaced during a rebuild with new components are:
- oil pump
- water pump
- valves, valve inserts, valve springs and valve stem seals
- piston rings
- new flexible pipework and gaskets and seals.
I guess if you can DIY, that might allow you to put some of the money saved towards things like having the crank and flywheel balanced and maybe some mild porting done on the head?
Chris
