My latest project MK1 1.8t Quattro Build
I set about removing all the brackets for the brake and clutch pedals from the golf column to make way for a bias pedal box.
There was already a bit of rot up above where I wanted to mount the pedal box, so I chopped that out and replaced it with something more substantial to stiffen up that whole area
Finished the pedal box mounting frame
Pedal box mounted, and TT throttle pedal fitted
Sent from my M2007J17G using Tapatalk
Looking forward to the next update!
'78 Golf LS 20vt
‘08 Mk5 Edition 30 DSG
Re:
Thanks man [emoji1303]white_78 said
Some epic work going into this! I’m just on doing my pedal box at the moment and glad to see we have had the exact same idea - still collars mounted up into a strengthened rain tray - hopefully it hold up haha! Mine that is not yours, looks a lot more sturdy[emoji23]
I've actually progressed quite a way since my last update, I'll try and get around to posting some updates later on (I've got a ton of photos, but they're all mixed up from transferring to a new phone so I've been putting off trying to get them in some sort of order and making a post [emoji1787])
frug said
[Thanks man
I've actually progressed quite a way since my last update, I'll try and get around to posting some updates later on (I've got a ton of photos, but they're all mixed up from transferring to a new phone so I've been putting off trying to get them in some sort of order and making a post )
Class, looking forward to seeing the progress!
I was looking back over my project and half of my photos were on photo bucket from the old days 😂, will need to recover them somehow!
'78 Golf LS 20vt
The propshaft tunnel has been chopped about a little and is bolted in its final position (obviously it will be welded, but i'll leave that for later, just in case)
Engine mounts have been fabricated, and the front half of the prop from the centre bearing forward fits nicely.
One of the issues i've come across is, due to the alignment of the prop and clearance of the steering rack, my inlet manifold isnt going to 'fit under the bonnet, because of the prop , i can't tilt the or lower engine much like you can in a FWD application. It took some thinking about, but i have a solution, more on that later…
I've sourced a turbo and exhaust manifold.
Bonnet and front wings test fitted along with standard front TT brakes and some 16" BBS reps to check everything clears and looks good
MK2 GTI radiator sourced and test fitted.
Various other goodies bought and stockpiled.
Heres a few pics of the front end all dressed up not sure if the wheels will be my final choice, but they were cheap enough, and local so i grabbed them. I quite like the look of them on the car though.
The turbo is a Holset, its a bit of a mish mash of bits, but is eseentially a HX35 compressor and non wastegate quick spool exhaust housing with a watercooled HX38 centre cartridge. I reckon it'll blow a more than sensible amount of horsepower as is, but can be upgraded pretty cheaply and easily if need be. The manifold is a cast T3 with external wastegate, its chinese, but actually looks half decent quality
Its kind of hard to illustrate how it all goes together without being able to weld it myself, but hopefully you'll get the idea.
I made a frame from 50mm box section to go around the boot floor and get some strength into that area, the side sections going around the inner arches were made by tracing card templates and then using them to transfer marks onto the box section for the pie cuts needed to make the bend.
The whole frame was then welded into the boot floor and chassis legs, and plated up into the inner arch.
Confident nothing was gonna move, i pulled the engine/box out and removed the front suspension, and then lifted it back onto the rotisserie, before getting brave and starting chopping out a bit more excess golf.
In its standard width, the whole rear end is obviously far too wide to just 'fit' in there, so i had to narrow things down a little to get somewhere close to the correct width, however, the mounting points for the trailing arms were still too far apart and would have been close to the outside of the sills, which isnt a particularly strong area, and would make some of the trailing arm visible when looking at the side of the car. The only solution i could come up with was a bit of a compromise, but im confident it will be fine.
I narrowed the suspension a further 60mm each side, this isnt quite as simple as you might think, as the control arms are angled back slightly, so removing 60mm will narrow it slightly less than that. I'm pretty sure Pythagoras has some sort of theorem that would allow me to calculate this myself, but i trial and errored it The missing 60mm was put back with a wheel spacer on each side,
Im not really a fan of wheel spacers, and im not proud of myself, but sometimes you just gotta do what you gotta do, and, props to the company that made them, they look quality and were CNC'd up to my spec within a fortnight.
My completed suspension 'jig'
Rather suited with how its coming together.
Next job is to modify my jig so i can try the propshaft in, as this will dictate the angle of the haldex cradle.
I'd already been around it with a tape measure, and had a fair idea it was going to be pretty close to fitting, but i couldn't believe this stroke of luck…. with the centre bearing in the middle of its slots, the prop is almost exactly where i want it.
I then built the top frame out of 25x50mm box and welded it to the top of my captive nut plates
Mounting plates for trailing arms were traced off the original TT parts which i'd cut out of the car
micky1 said
Fantastic, where you at with this now frug
Things are moving along nicely Micky…..
Updates to follow
Made up a couple of crossmembers to tie the sills into the tunnel and support the floor, I don't need them welded in yet, but they'll come in handy later.
I spent literally hours searching the internet trying to find something suitable, or close to suitable with some modification, but came up with nothing. I'd been hoping to get some made up by AVO as we'd had a good relationship with them at work, but, it seems they've gone bust….
So it was time to get creative.
It turns out the Mk1 Golf uses about the shortest shock inserts available, so i got myself a pair of Koni adjustable inserts and some seamless tube to make the shock lower legs from, Rally design supplied the weld on spring perches, I'll leave these until i have my spring weight and length sussed before i commit to welding them.
The TT hubs have a small step that the shock absorber body rests on , ensuring it can't slip through, i die-ground this away as i wanted to get as much of the shock poking through the hub as possible. The more height i save here reduces the chance that I'll have to raise the strut tops, which, if possible, I would like to avoid.
The OD of my tube is a nice fit on the spring perches, but is a bit too large to fit the hubs, so some lathe work was needed to turn the bottom to the right size. I also bored out the inside of a pair of spacers to hold the dampers central in the shock absorber bodies.
I used some temporary tags tacked on to the trailing arm mounting plates to hold them in place whilst i check everything is aligned and im happy with how everything fits and looks, and then welded the haldex frame in place.
