Wobbly Crankshaft flywheel/rumble from engine block
(In Topic #235281)
I noticed a rumbleing noise coming from my engine and saw that the crankshaft pulley is wobbly.
Is this as simple as changing the pulley, or is there a bigger problem in the engine that is causing the flywheel to wobble.
I can't tell if it's the wobbly pulley that's making the rumbleing sound or the cranksaft itself.
Am I looking at a new engine.
Please help
Thanks in advance
Last edit: by zod
for the time you put into your reply, much appreciated.
By the way when I said 'flywheel' in the subject heading that was my mistake, I meant to say pulley.
I checked the pulley bolts and they are not loose.
The noise is not that loud it's like a low rumble, a bit like a diesel although my car is petrol. Initially, I thought the noise was the alternator bearings but I eliminated that.
If you don't know Mk1s you may struggle to hear it, but I know my car and what it should sound like and it doesn't sound right.
Thanks again for your help, even though your opinion is what I feared.
I think I'm gonna have to book it in for a full diagnosis and pray that they say that the cause of the rumbleing is just the pulley and changing that will fix the problem. I should be be able to tackle that , but realistically I think I may be in the market for a new engine. Any suggestions around NW London/Middx area would be greatly appreciated
Unfortunately I can't refer any good places I do all my own work and I'm in USA, so no clue what's good places there around London mate, sorry. I'm sure other on this forum can point you in right direction for that though.
Also last stupid question, do you 100% know that the crank pulley is wobbling? Or you just think it is? If it's not wobbling, the noise you described could also be that maybe your timing belt has jumped a tooth and your engine is just slightly out of timing. Seen that before a few times also. I would check all your timing marks and see if everything is lined up where it should be.
Thanks for coming back.
Yes the pulley is definately, visibly wobbly and I'm the only one who asks stupid questions.
I don't think that the timing belt has jumped a tooth. The car is my daily drive so I think I would have noticed, unless the difference of a jumped tooth is very subtle. I haven't noticed a change in performance since I noticed the noise.
I first noticed the rumbleing sound at the end of a 30 mile journey at 60 - 70 mph during which the car drove as it had always done.
Thanks again
Do you know the correct torque setting for the crankshaft pulley bolts?
I think I'll try replaceing the pulley first and eliminate that and hope that that's a cheap and quick fix.
I'm not sure the engine would even run if the crankshaft bearings were worn to a point where the pulley wobbled, the oil pressure would certainly be down.
Thanks for weighing in, you have put my mind at ease.
I hope that it is just the pulley that needs attention, but I'll just get a new one, I don't trust my inspection skills.
I will of course clean off the mating surfaces first - that much I can do.
Thanks again
Regional Host NE
The pulley bolts were the first thing I checked and they are not lose.
The rubber in the centre seems OK also. If the rubber had deteriorated would there be an oil leak? I'll check again when I take the pulley off.
Thanks again
Regional Host NE
Are you saying that I should replace the crankshaft oil seal as well, while I've got the pulley off?
Is that not a sump-off job?
The pulley has to go on the right way so the TDC mark lines up, is yours okay in that respect.
From what I can tell there are no oil leaks from the crankshaft, and I'll double check the timing markings.
So I'll take your advice and just change the pulley first and keep my fingers crossed.
Thanks again.
