Pistolpete's Lhasa Green Mk1 16v Restoration
Here we go again!
Pistol said
Carbs completely finished now with the last bits zinc plated. I'm so pleased with the finished article. All credit to Ultra Vapour Works (in Northern Ireland) for the work done on these.
They look amazing .
Shell has been completely stripped, blasted and coated in NOVOL for Classic Car Epoxy Primer.
Spent about 20hrs prepping this. Then used Eastwood etch primer, Aluma Blast & Diamond Clear lacquer to cost it. Bolted on a couple of the newly vapoured & zinc plated linkage brackets. New release bearing & end cap.
There was me thinking it wasn't going to be as perfect as your last one!
If it is any consolation, I've only manged about 300 miles in mine since the last Mot a year ago. Lots of tinkering, not so much driving.
J
I've been busy working on the other stuff. Mainly the engine which has now been fully rebuilt with all new bearings and rings. Block was re-honed. I got myself new micrometers, bore gauges and calipers to size everything up properly and it is all spot on within tolerance.
Sent off loads of stuff to be powercoated.
And finally got the head back on the block, so it's a 9A 2.0 16v with KR head running piper cams and will put the twin Weber 40's back on.
paceman said
Nice work! I love engine building. Should go pretty well, assuming you'll drive this one 😉
Thanks J, believe me this one is getting driven. I'm aiming to get to the AGM this year and ambitiously set the bodyshop the target to get the shell back to me so I have 2 months to rebuild. We'll just see how that all pans out!
The shell is still sitting in the bodyshop, and still in exactly the same state as the last picture of it in epoxy primer. I'm not sure how long is considered too long to get a full bare shell resto completed, but it'll be 2 years come February since it was dropped off. I think I just hit the complete wrong time with the guy, as he used to do restos in his spare time from his day job in a big name bodyshop. I left car into him just as he was starting out on his own after giving up the day job and he's been snowed under with work since. Disappointing all the same.
In the meantime, I have been getting as much stuff ready as a can for the eventual rebuild.
9" brake servo and 22mm master cylinder upgrade with refurbished linkage etc.
Steering column stripped and re-painted.
I've been patient up to this point but now gone beyond a joke so I'm pulling it out of there and have found another bodyshop to take it on. Hopefully I can start to get some progress in 2024.
